14 Sep 2010, 19:59
Post
#1
![]() DT ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Group: Members Posts: 5,195 Joined: 15-September 03 From: France Member No.: 2 |
![]() 1055 FORD MKII GT40 24h Le Mans #3 red The first livery will be on the market next week at a retail price of 75.00 Euros (£63). ![]() ![]() The bodyshell is made in 3 separate parts for better look. Inside the cockpit there is a four pieces driver, steering wheel, gear shift, motor and other small pieces. ![]() NSR always try to improve quality of products; this time they added two photo-etched grills. ![]() Body dimensions are 61mm width, 134mm lenght, 32mm high. The wheelbase is 75mm and the distance from centre of rear axle to centre guide is 92mm. The weight of the fully accessoried and painted bodyshell is 19g whilst the weight of the RTR car it is 70g. ![]() ![]() ![]() ![]() The first livery version of the Ford MKII GT40 reproduces the 24h Le Mans 1966version, red #3. ![]() Second livery will be Winner of 24h Le Mans 1966 black #2; it will be included into "SET04 FORD Le Mans Winner" together Ford MKIV #1 red. It will be on the market November 2010 ![]() Third livery will be yellow #8 of 24h Le Mans 1966. ![]() Chassis The main chassis is nylon made "flat" design of 1 to 1,5 mm thickness for maximum grip when cornering whilst capable to withstand crashes. Sidewinder motor support is held in position to main chassis by three screws (one in front and two at the side) which are only crossing it to screw into an independent ring. This allows the motor support to move independently from the chassis and in the desired amount (which can be set by simply unscrewing the screws from underneath). The motor is of a sidewinder configuration with two degrees from the rear axle. The chassis comes with a removable traction magnet, located just ahead of the motor; the neodymium magnet is round, 4mm high and 8mm diameter with two different mounting positions. The guide is counter-sunk well inside the chassis to allow desired ground clearance by the use of thin spacers to be placed in between the guide itself and the chassis. The one piece front axle can move vertically. Rear pillow block height allows the gear to protrude only 1mm under the chassis level thus leaving still 1 mm. gear/track clearance. Guide The guide is similar to that of current offerings, but it is low-profile (only 1mm thickness); exclusive adjustable height using .005", .010" or .020" new spacers, to cater for racing on all types of plastic tracks, as well as wooden tracks with raised, flush or recessed braid/copper tape to optimise the braids contact. The pivoting shaft is 8mm. high for a free vertical movement. The brass connectors used to fix the wires to the guide are newly made, slightly bigger, chosen to guarantee a tough contact with our smallest thickness braids. ![]() Mechanical The components of NSR Ford MKII GT40 are made up of the usual high-quality from NSR: NSR1369 Medium black chassis NSR1224 Narrowed Xhard black sidewinder short can motor support NSR3004 20K Shark motor, 20000rpm 164gr-cm NSR4801 precision and very strong 49mm x 3/32" diameter axles NSR5001 aluminium 16mm. diameter 'front - NO air system' 4/40 set screw front wheels NSR5002 aluminium 16 mm. diameter 'Air System' 4/40 set-screw rear wheels NSR5233 'No-friction' hard front rubbers 20 x 8.5mm (the same of Ford MKIV) NSR5236 'Supergrip' rear softer rubbers, 21 x 10mm (the same of Ford MKIV) NSR4803 Auto-lubricating & no-friction bushings NSR6911 Extralight & no-friction 11t pinion NSR6032 Extralight & no-friction 32t black gear 17.5mm NSR4841 Low friction racing pickup guide Motor The motor for the Ford MKII GT40 is the Shark 20K, fully developed by triple World Champion Salvatore Noviello, made always by the same NSR philosophy: to realize high performance product without compromises! Shark 20K motor has 20000 RPM at 12Volts with an excellent torque value of 164 gr/cm, an exceptional value, previously obtained only from "long can" and heavy motors. The motor can is opened from both sides, it has cooling oval holes and the magnets are ceramics. NSR Policy 'Ready to Run' is not enough! NSR's objective is to make a Classic car using modern technology, so high tech 'Ready To Race'. It needs to be competitive straight out the box, without any fiddling or modifications required to make it perform properly and we believe that this third car has also achieved this target. Our policy is to offer really a 'Ready To Win' car; we never like it when people need to buy aluminium wheels to replace plastic wheels, soft rubbers to replace hard rubbers, or a motor to replace slow box stock motor…! The NSR Ford MKII GT40 is another innovative model with high-tech components, highly performing on track still respecting the scale modellistic aspect. The NSR Ford MKII GT40 was created in the streamline of the Mosler GT project which has dominated in the GT top class either in National and international competitions since it was born in 2006. In according with our NSR philosophy, we have worked to obtain the best performances without any compromise. The NSR "Classic" model cars are without doubts the fastest in the world. Manufacturing costs and artisan labor in Italy are however significantly higher than China or East Europe, but NSR is very proud of the fact that all the models are completely and entirely built in Italy, thus allowing NSR to have absolute control over quality and to demonstrate our Country capability. All NSR Ford MKII GT40 cars are assembled and tested exclusively into NSR Factory and only by NSR employers, so NSR can offer full warranty about final product. Retail price will be in proportion to the quality of product. |
14 Sep 2010, 20:05
Post
#2
Jon Grainger ![]()
Group: PLUS+ Posts: 3,459 Joined: 12-May 05 From: Norwich, Norfolk Member No.: 2,378 |
Looks very nice! Not the closest scale model of a GT40 I've ever seen, but very nice all the same! Sure it will go like hell on the track though!
14 Sep 2010, 20:11
Post
#3
Top Tuner ![]() Group: PLUS+ Posts: 435 Joined: 13-November 07 From: 45000 ft Member No.: 7,929 |
Noooooooo, looks like Sept/Oct will be an expensive month.
Looks lovely. m -------------------- |
14 Sep 2010, 20:20
Post
#4
Ian ![]()
Group: Admin Posts: 7,961 Joined: 24-February 05 From: Lincoln,Lincolnshire,UK Member No.: 2,098 |
I'll have to have all three just to try them
-------------------- Ian B
14 Sep 2010, 20:33
Post
#5
Tea Boy ![]() ![]() Group: Members Posts: 38 Joined: 2-April 10 From: ALMERIA SOUTHERN SPAIN Member No.: 14,933 |
My thoughts entirely |
14 Sep 2010, 20:36
Post
#6
![]() Tel ![]()
Group: PLUS+ Posts: 3,410 Joined: 29-December 05 From: Cambs UK Member No.: 3,329 |
I'll pass
-------------------- My old track: Savage Raceway Scalextric Digital with PBPro SH, Pit Pro, RichG lapcounter and SSDC
Current track: Hunter Valley 3 Lane Analogue routed MDF with Race Coordinator timing and fuel management |
14 Sep 2010, 20:45
Post
#7
Ian ![]()
Tel,
I nearly fell off my chair, you're getting funnier with every post. It really could have been Victor -------------------- Ian B
14 Sep 2010, 20:50
Post
#8
![]() Tel ![]()
I bit my tongue Ian, didn't want to start a flame war, but I am sure you know all 4 issues I have with it
14 Sep 2010, 20:51
Post
#9
![]() Peter Rondel ![]()
Group: PLUS+ Posts: 5,434 Joined: 4-May 05 From: @ your screen Member No.: 2,345 |
I feel something blue/orange commin up in a year or two tops............ hit me hit me tadaaa
14 Sep 2010, 20:57
Post
#10
Ian ![]()
14 Sep 2010, 21:13
Post
#11
Racer Dude ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 239 Joined: 13-September 05 From: Canterbury, UK Member No.: 2,782 |
I am a huge GT40 fan and have been as a schoolboy ever since they first appeared.
The front of these cars pictured here is far too low and the wheels are far too high up in the wheel arch, it almost looks like the car has suffered a front suspension failure or is in the permanent posture of an emergency stop! Faults like that are very irritating. Stan Kirk. -------------------- Stan Kirk
Timaru MCRC (Broadstairs, Kent, UK) www.timaru.co.uk Timaru on Slotforum Where we race, The Crampton Tower Museum |
14 Sep 2010, 21:24
Post
#12
Top Tuner ![]()
Group: PLUS+ Posts: 421 Joined: 22-May 06 From: MOLESEY, UK Member No.: 4,150 |
I dont really understand why anyone would want to collect NSR cars ...
they are all stylised versions of a car to make them absolutely fly on the track .. which they do very well. Finish is pretty rubbish for collectors .. paint bubbles, badly fitting lights/parts, flash on the parts, mould marks on the body shell... The GT40 probably wont be any different that any of the others .. just look at the photo etch part that is slapped in the radiator outlet.... and look at the real car ... that bit just isnt there .. however photo etch parts make the car "sound" better if you use those parts in your construction..makes it sound more scale etc ..... NSR doesnt need scale ... its just speed thats inportant. Just race them thats what they do best. -------------------- ![]() 170 FT of 6 lane NINCO on your doorstep! 5 minutes from Hampton Court - West Molesey, Surrey KT8 2LG |
14 Sep 2010, 22:06
Post
#13
Phil Kalbfell ![]()
Group: PLUS+ Posts: 2,523 Joined: 21-September 03 From: Hobart Tasmania Australia Member No.: 89 |
Looks like another thingie from NSR! But the chassis made be useful to use under a body that is closer to scale.
But I am sure it will sell to the speed freeks that are happy to race them. -------------------- |
15 Sep 2010, 01:14
Post
#14
![]() Learner Driver ![]() ![]() ![]() Group: Members Posts: 93 Joined: 11-April 07 Member No.: 6,800 |
LOL.................I will be buying one or two of these Phil!!
Lets not let this news section turn into a scale war though. If you want to go fast and your club allows these....then away you go..............if not.........c'est la vie |
15 Sep 2010, 01:44
Post
#15
Racer Dude ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 239 Joined: 11-March 07 From: melbourne Australia Member No.: 6,618 |
My opinion of the car is a very positive one. The shape is spot on and the stance is great.
I know it's very low slung but i don't think every time NSR produces a new piece we have to be reminded of the existance of guide shims, they tend to be under $5aud a bag, and you can make it Dakar style if you like. This car will make a great addition to my collection, right next to my Fly version of the same car. |
| Lo-Fi Version | Time is now: 20th May 2013 - 06:57 |
