News from Slot.it
Sauber-Mercedes C9 - n.62 Le Mans 1987
Drivers: C.Ganassi, J.Dumfries, M.Thackwell
Code: CA06h
With new chassis CS05t-60b
Official selling date: November the 18th
The Sauber Mercedes C9 was a Group C race car, built by Sauber in partnership with Mercedes-Benz.
Chassis was mainly an aluminium monocoque, with magnesium elements and carbon-fibre skins. It had double wishbone suspensions, with direct-action at front and rocker-arm at rear, as well as Speedline magnesium rims, 17" front and 19" rear, and Brembo cast-iron 14" disc brakes.
In 1988, the car was powered the 'M117' engine, a twin turbo, 5 litres, V8, with semi-stressed function, which used the 500SL passenger car crankcase. The two valves per cylinder were controlled by a single over head camshaft, with chain drive. In qualifying specifications, the boost pressure was 1.2 bar, and power was 800 bhp at 7000 rpm. Torque had a very flat band from 3000 to 8000 rpm, which gave the Sauber C9 a great advantage in exiting corners. Overall weight was 865 kg.
This second Kouros Racing Team car raced at Le Mans in 1987. It was driven by Johnny Dumfries, Chip Ganassi and Mike Thackwell.
Images and information as supplied by Slot.it
