Upgrade your SSD in Car Controller
56K views 170 replies 37 participants last post by  Dr_C
#1 · (Edited by Moderator)
Have been meaning to try this for a while. However first a word of warning. Have only modded one of these, seems to work, but there could be problems yet to find. This is not an easy mod to do physically.
This mod can be viewed either as a way of repairing a failed Saloon board or as an upgrade to the output stage. I suspect most failed boards have one or both of the output mosfets failed.
The device I have chosen to fit as a replacement is the one used by Scalextric in the early Powerbase's, the ZXMC3A16D. If two of them were nearly good enough to power 6 cars, one should be well over the top for one.
The output mosfets are the small black devices marked N02 & P03. First these need to be removed. Apply a soldering iron to the two connections on one side & when the solder melts flip up the device with a screwdriver, now desolder the final connection and remove the device.
To fit the device you need to slightly splay pins 1 to 4 in an outward direction to make them fit the four pads marked in red in a row on the picture. Be very careful not to bend the leads too close to the body of the IC and only tweak them just enough to reach the edges of the pads. The 4 Drain connections, pins 5 to 8 are then connected to a piece of tinned copper wire and the ends bent and soldered to the two remaining connections.
So thats it.
Have never been able to find a spec for the P03 & N02 devices. I assume they are mosfets, but have seen Beppe post that they are transistors?
However here is a comparison between this mosfet and the DF2C03 used by Slot.it in their new decoder.
As you can see it compares favourably in all respects.
The disappointing part is that in testing, I modified a Takara module for ease of swapping, the performance seems identical to the original. This is confirmed by on track performance and by measuring the voltage at the motor.
I therefore expect the gain to be with beefier motors and hopefully that it will not expire.
Ideally need a few people to try this and report back. Very little to loose if you have some failed Saloon boards. This will of course also work with the F1 board.
Farnell part nos for the ZXMC3A16D is 756-4953
Rich
  • Like
Reactions: Marconi212003
#5 ·
#6 · (Edited by Moderator)
Hi Bryan
Thanks for the info on P03 / PDTA114ET
Have had a look at the data sheet and am sceptical as to weather it is the correct device.
P03 is used to short the motor for Braking and N02 to feed the PWM signal to the motor.
I am concerned about the rating which is only 100mA & 150mW.
Also seems strange that the N02 transistor is not listed as they are likely to be a complimentary pair of either transistors or mosfets.
I think I found this data or similar a year ago when trying to track down P03 & N02 however my memory is failing me. Looking at my scribbles on the sheet that I roughed out the circuit diagram I think I came to the conclusion that the X reference was wrong and that the transistor is an A03. However as I say it is scribble.
Also seems odd to me that they would not use a mosfet in this application. Equally odd that I am getting identical performance after grafting in a mosfet.
Beppe if you are there, where did you get the info that these are transistors?
D. Not sure if this is what you mean but here are the Scalextric instructions for fitting a saloon ship to a dummy Takara module. As you have seen I have not followed it for the LED but have done that the same way as the ready made digital modules to put the LED further foreword.
#7 ·
Although I do not know a thing about electronics,I have found the NASCARs to run well on the 30,000 rpm light blue scalextric motors...........except when using the braking buttons.The lap times increase with the dynamic brake,but the chip will fry very fast.I was going to mail you some chips once before Rich,never did.If you let me know where to mail them,I will send you a dozen or so.I am on vacation this week,so I will be sure to get them to the post office this time. Sounds like your on to a high performance upgrade!
Greg
#8 · (Edited by Moderator)
I fry a SSD chip (25k motor) after a 30 minute session, its ok till you stop, as soon as you stop you have no air flow (cooling), then the mosfet buggers up, the next time you use it , it is on full throttle by itself. Taking off the shell to expose the board, I seen the mosfet glow red and fry after trying again on track (experiment). This upgrade might be the go, I just bought a magnifying glass, mini soldering iron, and a light too, so good timing.
#10 ·
OK I stand corrected twas Mauro.
QUOTE (Xlot @ 9 May 2006, 13:38) <{POST_SNAPBACK}>If I understood Mauro correctly (something not to be taken for granted
), the performance of the Slot.it decoder should be - surprise, surprise - noticeably superior to that of the SSD original
This because the output stage uses low resistance MOSFETs instead of transistors, effectively eliminating the good 2 Ohm choke now present
Rich
#13 ·
Hey Rich,
I too am suspisous about the datasheet I found because these devices can only stand a few hundred mils, Not the 2 - 2.5A range you would suspect. I assume that you have mapped out where the pcb traces are going. I was thinking that they really only need a half bridge arrangement to provide forward drive and braking. Do we know what the other components labeled a8e are? Do you know if we are working with a full bridge or just a half bridge? The p03 and n02 components could just be used to provide supply level voltage to the other components (a8e, maybe fet?) gate? If you already mapped the circuit, let me know, otherwise I will give it a closer look.
best regards,
BT
#14 ·
Hi BT
I have scribbled out the circuit.
A8E are the driver transistors, one for each mosfet. I am going to assume they are mosfets until proved otherwise because I do not think it would make sense to use anything else.
The N02 device is in series with the motor & driven via an A8E driver with the PWM signal from the processor. The P03 device is across the motor & is driven again via an A8E driver with the brake signal.
All pretty simple, was just curious as to the spec of the original devices, but not important.
Rich
#15 · (Edited by Moderator)
QUOTE (NASCARUSA @ 21 Jul 2006, 10:55) <{POST_SNAPBACK}>Although I do not know a thing about electronics,I have found the NASCARs to run well on the 30,000 rpm light blue scalextric motors...........except when using the braking buttons.The lap times increase with the dynamic brake,but the chip will fry very fast.I was going to mail you some chips once before Rich,never did.If you let me know where to mail them,I will send you a dozen or so.I am on vacation this week,so I will be sure to get them to the post office this time. Sounds like your on to a high performance upgrade!
Greg
Well the chips arrived from Greg this morning. If you think you have problems with fried chips, look at this.
So I thought I would share my findings as I go along.
Have only visually examined the chips at the moment, there are 3 obvious problems.
1) Fried mosfet. Always seems to be the N02 device, not suprising as this is the one that drives the motor. The P03 device is only used for braking.
This is usually visible as a bump on the surface of the chip, although some are more dramatic.
2) Failed Diode. These are the four larger block devices marked FS1A
Here you see a quite dramatic failure.
3) Desoldered Diode. This one was a surprise to me. What has happened here is that the Diode has become sufficiently hot that it has desoldered itself from the board.
This also seems to be the most common failure. Question for Greg, in the pack there were a lot of loose diodes, just want to check that these desoldered themselves, as opposed to you removed them?
So here is the final tally of the 32 failed boards.
Of course this is only a visual inspection, some boards may have multiple faults, it is also likely that a failing mosfet could cause the Diodes to overheat and desolder. Also the the boards without a visible failure will have something wrong with them.
However one thing is obvious. If we are going to get a beefier board, as well as the upgraded mosfet we are going to need uprated diodes and or a higher melting point solder to keep them in place.
Final note on the diodes. They are an FS1A rated at 1 Amp continuous and 30 Amps peak forward surge.
This should be ok for most cars. Greg do you know how many amps your motors take?
I note that the Slot.it board uses a device marked RA 63A but can find no data on this. Can anyone else help?
To be continued....
Rich
#17 ·
@ drummer ,
oddly enough out of the 100 (I really need to stop counting them ) or so chipped cars I have, the only 2 chip failures were with an SCX marenello ! , third chip has been succesful , no changes made to the installation method either ??
sax
I just mentally added up the cost of all those fried chips............ouch !!!!
#20 ·
Hello Fellas,I have been out of town.Those chips are from a year and a half of racing.Most of them were destroyed with the 35,000 rpm,red can motor.When they blew,we just laugh and say Thats racin!Most of the loose chips were the result of crashing when the cars were hot.Most were blown in excess of 15 volts.We now use the 29,000 or 30,000 scalextric light blue motors,at 14 volts,and have little problem,we may still run at 16 volts for a 50 lapper.I have 5 NASCARS with the standard motors,and when run at 14 volts,it all works fine.We have 4 NASCARS with the 29,000 light blue scalextric motors.Two sets of cars for two differant skilled drivers.We are powered with the 10 amp 5 to 20 volt power source.I know those chips lookfunny,but I can say we had a blast finding the limit of the system.We still have a #3 Dale Earnhardt with the 35,000 rpm,always seems good for one race.There are 3 of us that race a couple times a week,2 to 3 hours at a time,usually after work.This is great stress release,and has been well worth the expense.When racing NASCASRS,speed is the ultimate goal.Hope Rich can find us some more speed,cause we have surly found the factory limit.
Greg
#21 · (Edited by Moderator)
Hi Greg
Thanks for the extra info. Do you know how many amps the 35,000 rpm, red can motors take? Also does anyone know where I get one in the UK to do some tests with?
Have not investigated the failures any further, however have made on discovery.
Seeing that many of the bridge rectifier diodes had expired or desoldered themselves I dug out the spec for the FS1A.
I had assumed it would be a Schottky diode, however it turns out to be an ordinary silicon diode with a rating of 1 Amp, but more importantly a forward volt drop at 1 Amp of 1.3V. So this is not only losing us precious volts, but it is this power dissipation which is desoldering them.
So am now trying to source a suitable Schottky diode which should reduce the volt drop to a max of 0.5 Volts, this will also significantly reduce the power dissipation. A win
win.
Am not sure if I can find a suitable diode in the same package so solution may be to have the bridge remote from the board. This will mean that the wires from the guide go to the bridge and then to the board with it's bridge removed.
Another possibility is to resite the smoothing capacitor with the separate bridge, enabling the end centimeter of the board to be chopped off.
If it works this should be a big gain.
#23 ·
The red motors are showing about 2 amps when taking off down the long straight.We usually raced only three of these at a time due to the powerbase overload,of course the track switches are seperatly powered.We had one red motor and chip that outlasted the others by far.I will try a send you a red motor or two,as I have plenty of these too:),although,unlike the chips,they are still usuable.We call em the big red chip friers.I am also getting a nice collection of junk throttle controls.Also.........if you add a second magnet to try and help hold the car on,it really cooks quick.......but it is an amazing site to see three cars run like this.
Greg
#24 · (Edited by Moderator)
Hi Greg
Ok on the 2 Amps, no wonder the FS1A are not happy.
Will look for some 3 Amp plus diodes, these will not be the same size, so will have to be remote from the board.
If you could send me a motor that would be great, saves me having to look into and understand motors ( not my specialist subject) I assume these will just drop into something, ideally my slot.it Audi R8C or one of the Scaley Boxters?
When I have something that seems to work I will mend & mod four of the duff boards and send them back for test / destruction.
Sounds like you need some of Pete's throttles, my discard pile is growing all the time, and the ones that are ok are only just. My best throttle yesterday got a weird one when you press the LC button the car moves forward, still operating the LC's. Would not usually matter except that I use a 4 second push and hold on the LC with zero throttle to reset the display, which does not then work.
Rich
#25 · (Edited by Moderator)
OK Guys you are going to love this.
Remember the power the lane changers separately mod,
remember the sort the throttles out mod,
well this mod is in the same league.
So a bit of a bodge but the only Schottky diodes I had in stock were wire ended SB130. Still 1 Amp but more importantly the forward volt drop at 1 Amp only 0.4 Volt.
So here they are soldered in in place of the FS1A, which remember has a 1.3 volt drop.
I have been doing my testing in a JGTC car. The modules make it very easy to change chips.
Had been running at 15 Volts. Swapped the chip and the car was uncontrollable.
Turned the volts down to get the same performance and ended up at 13.8 Volts. So only a quick test, but this is a big performance gain and has the added bonus of wasting less power.
Let's just hope the FIA don't ban Schottky diodes.
So not the ideal device. I will now try and find a better one, but has proven the point.
Scalextric please change to Schottky diodes asap, you will significantly improve performance and reduce failures.
Rich
