23 Mar 2012, 11:39
Post
#1036
![]() Magic Smoke Restoration Club Member ![]()
Group: PLUS+ Posts: 3,724 Joined: 31-January 09 From: Oxfordshire, UK Member No.: 11,296 |
Avant Pescarolo
Number of downloads: 23There are two - they look the same but one is a special with lightweight interior and other things. No, I can't tell the difference either.
Number of downloads: 66They are both fitted with 27k Hurricane motors and seem to be happy with the diode upgrade on the F1 chips. -------------------- Beauty is in the eye of the beer holder
15 Apr 2012, 19:04
Post
#1037
Tea Boy ![]() ![]() Group: Members Posts: 11 Joined: 31-October 11 Member No.: 19,017 |
I chipped my AUTOart Mitsubishi Lancer Evolution VII WRC with a normal size chip. It was a bit tricky...
Check it out at my blog. |
15 Apr 2012, 21:19
Post
#1038
I finally got around to chipping the new Jaguar. Originally I thought that there would be loads of space but the space in the side pods is mostly taken up by the cockpit. My strategy required a re-think as the inline motor filled what space there was in the front.
Number of downloads: 38I wanted to leave as much free space in the front as I could so I moved the Ferrite man back to sit in the side pod. This also a neat way to extend either the pickup or motor wires.
Number of downloads: 34The LED was a tight fit just in front of the motor. The ends were carefully splayed to allow for the drive shaft full freedom of movement.
Number of downloads: 47All the main wiring is now in place, I just need to add the wiring for the lights, as this is an Incar-Pro chip I needed a full set.
Number of downloads: 71The front lights can be seen and the chip fitted snugly in the back tacked in place with some hot glue. The rear lights can also be seen to the right.
Number of downloads: 28All back together again ..... and off he goes. -------------------- Beauty is in the eye of the beer holder
25 Apr 2012, 08:45
Post
#1039
Tea Boy ![]() ![]()
Group: Members Posts: 32 Joined: 8-February 12 From: Athens Greece Member No.: 19,992 |
Hi Greg.
So you made id 1 week earlier than I. I used instead an F1 chip and mount in by the drivers side. I will try to post pictures in the afternoon. Regards |
26 Apr 2012, 19:50
Post
#1040
Hi Anthony, I saw you pictures in your other thread ....... nice job
23 May 2012, 06:18
Post
#1041
![]() Sir Slotalot ![]()
Group: PLUS+ Posts: 2,044 Joined: 6-March 09 From: Slough, Berkshire, UK Member No.: 11,632 |
Greg K
Which chip upgrade are you referring too, I've just brought a few avant slots and would love to run with the 27K motor, otherwise I will have to fit a lower rated motor. Thanks Colin -------------------- |
24 May 2012, 19:17
Post
#1042
Hi Colin,
To run the 27k and the 25k motors I uprated the 4 diodes, these are the ones marked FS1A. These exists on the saloon, F1 and the DPR chips. Great care needs to be used when removing them as they have been glued in place and it is very easy to rip the fragile copper tracks off the PCB. The other problem, and it is bl@@dy annoying, is when you try and hold the little blighters in place before you apply the heat and they suddenly ping past your ear never to be seen again If I have a bit of spare time when I chip or re-chip a car, I tend to uprate the diodes as a matter of course. The reason being that the new ones are more efficient and use less voltage which means that it gives you a bit more grunt Cheers - Greg -------------------- Beauty is in the eye of the beer holder
24 May 2012, 19:34
Post
#1043
Digital=Realism ![]()
Group: PLUS+ Posts: 4,387 Joined: 12-December 09 From: kingswinford.West Midlands. Member No.: 13,786 |
hi
i would say Greg quite a bit more grunt. There was a noticable difference in the F1 chips you did for me. -------------------- |
30 May 2012, 19:58
Post
#1044
Newbie ![]() Group: Members Posts: 6 Joined: 21-May 12 Member No.: 20,624 |
I am new to chipping Scalextric cars and wondered if anybody can help me. I want to chip a Disney Lightning McQueen car and any advice as to which chip to use etc would be most welcome. Many Thanks |
30 May 2012, 20:16
Post
#1045
Ian ![]()
Group: Admin Posts: 7,977 Joined: 24-February 05 From: Lincoln,Lincolnshire,UK Member No.: 2,098 |
Scott,
Firstly welcome to the forum it's a great place to be. I'm a bit out of date when it comes to chipping -------------------- Ian B
30 May 2012, 20:34
Post
#1046
hi
with bleep on this one,wherever there is room always go for the saloon chip,it is much better and more reliable.. If space is tight then opt for the f1 chip but make sure you have capacitors at the pick up feet and more importantly at the motor end... Both of the above refer to the solder in chips rather than the dpr variety which need a trapdoor in the chassis to work.. -------------------- |
31 May 2012, 22:00
Post
#1047
Thanks for the help guys. I am mid way through chipping a 4x4 Focus RS but bought the Lightning McQueen for my girlfriend a few days ago and want to do that before I finish my RS. I will let you know how I get on.
Thanks Again |
14 Jun 2012, 15:45
Post
#1048
Avant Slot - Subaru Impreza No.3 Ojeda
This car is slightly different than most of the ones that I chip because it has a short drop arm, it's not particularly difficult to do.
Number of downloads: 22The LED hole had to be drilled slightly further back than normal because the arm was offset.
Number of downloads: 42The green & yellow wires were removed from the chip and replace with existing wires which I kept just long enough to reach comfortably to the chip. The motor wires were also shortened.
Number of downloads: 27The car all back together again; the LED is shown
Number of downloads: 21A quick run on my Display-Pro test track revealed this 4WD car to be very grippy and surprisingly fast with fantastic, easily controllable tail waggling ...... well worth buying -------------------- Beauty is in the eye of the beer holder
23 Jun 2012, 13:25
Post
#1049
Tea Boy ![]() ![]() Group: Members Posts: 10 Joined: 12-April 12 Member No.: 20,389 |
Hello, I not shure if this is the right place to ask....I chipped the ASTON MARTIN DBR9 red bull from SCX with the saloon chip of scalextric, exactly as described in one of the above replies......but.......it blew up after tree rounds.
Snif...was not able to drive it last night. Should I swap out the motor for a slot it? and install a slot it chip? Thx Next project for chipping is the DB5 from scalextric! regards Ivan |
23 Jun 2012, 13:56
Post
#1050
hi
yes the scx cars will blow the scaley chips. It may be possible to replace the scx motor with a scaley one or someone might be able to uprate the chips for you other than that you could go the slot-it route. -------------------- |
| Lo-Fi Version | Time is now: 25th May 2013 - 12:40 |
