76 Pages V  « < 11 12 13 14 15 > »
> SSD Chipping Database, Add the cars you have chipped.
Ian B
post 6 Feb 2006, 20:20
Post #168
Ian
Group Icon
Group: Admin
jmswms,
OK can you give us a bit of a hand here photo of the inside of the car? I have done a few Revell cars and had to fit the chip right at the back of the car? extending all the wires sad.gif
The Little "B" has to be done your right and would be great to have it running round your track what Manufacturer is it I thought it was Ninco or Carrera but can't find it still wont be that hard if you can find somewhere to hide the chip!
Ian B
Go to the top of the page
jmswms
post 6 Feb 2006, 20:42
Post #169
Bill
Group: Members
Bleep,
I do have a digital camera, but I can't figure out how to post JPGs on the Forum.
There is room inside the 550, but the motor is in the front so there's no room between the guide and the motor for the LED. And, the shaft is centered behind the motor so the LED can't really go behind the motor. Can I put the LED in front of the guide? Then I'd have to splice the LED wires which are too short to reach from the probable placement of the F1 chip in the back...
jmswms
Bill
Ian B
post 6 Feb 2006, 20:53
Post #170
Ian
Group Icon
Group: Admin
jmswms,
OK right, yes the LED can go behind the motor I would take the motor out to do it, there is usually enough room to fit the LED in place and the re-fit the drive shaft without it touching the top of the LED. You have quit a bit of space backwards from the guide and it will still work. I can't remember if you can actually fit it before the guide but I haven't tried it. biggrin.gif I hope this helps I will look for some photos of it done that way I'm sure I have seen some cheers for now thumbsup.gif
Just found this bit so the LED cant Go in front of the blade
QUOTE
FM RichG Lap counting & timing is a two part process. First sensor reads the LED to work out which car it is. Second sensor is a beam that is broken by the Slot Guide, this determines the time.
I know this is not the exact same as its a 4x4 but you can see what I mean "I Hope" LED under the driveshaft sorry Cr@p Photo wink.gif
This post has been edited by bleep: 16 Feb 2007, 18:42
Ian B
jmswms
post 8 Feb 2006, 08:14
Post #171
Bill
Group: Members
Thanks for the info Bleep. Thought I'd go the easy route tonight and I chipped my Ninco Austin Healey MKIII with an F1 chip. It could easily have taken the Saloon chip, but all I have on hand are the F1s. It was extremely easy to chip. And, it's a blast to drive; it fishtails all over the place, but usually stays in the slot. It won't win any races, but fun to drive around. (Laptimes are about 4.8-5.0 compared with 3.8-4.0 for the Boxsters on my track). I'm collecting a set of vintage cars that will have similar handling characteristics and make for interesting vintage racing. Still working up the courage to do the Revell Porsche 550...
Bill
jmswms
post 11 Feb 2006, 07:50
Post #172
Bill
Group: Members
Well, I worked up the courage to chip my "Little Bastard" tonight -- the James Dean Revell Porsche 550. I first tried putting the LED in front of the guide -- bad idea sad.gif -- it worked only sparodically for lane changing. So, I followed bleep's advice ( clap.gif which I should have done from the start) and put the LED behind the motor. Seems to work fine. thumbsup.gif It'll never be a racer, but it's fun to tool around with some of the other Ninco classics. It's quick, but it tends to deslot quite a bit on my rally track, probably because I've got some pretty steep elevation changes. It takes some skill to drive, but it's fun. I prefer driving the Ninco Austin Healey MKIII, but the Revell Porsche 550 looks to be a good race. They drive quite differently.
Bill
Ian B
post 11 Feb 2006, 08:41
Post #173
Ian
Group Icon
Group: Admin
jmswms,
well done, hey glad you tried both ways we never find things out if we don't try biggrin.gif shame it didn't work first time it always gets frustrating mad.gif but it worked out good in the end. You could try adding some lead to the front to help with the deslot problem. You'll need to post some photos I think its a great looking car just couldn't explain to my young son that we can't say that word then buy a car called Little "B"! lmfao.gif lmfao.gif lmfao.gif
Ian B
slot king
post 13 Feb 2006, 09:37
Post #174
Team Owner
Group: Members
I'm starting to chip DTM's!!!!!
Regards,
Ben
Ian B
post 13 Feb 2006, 09:42
Post #175
Ian
Group Icon
Group: Admin
Hi SlotKing,
Let us know how you get on Make, Model, What Chip, How you found it,
Ian B
JudeSudbury
post 14 Feb 2006, 16:39
Post #176
Learner Driver
Group: Members
QUOTE (RichG @ 3 Jun 2005, 14:48)
Have chipped my first GT40, 5 more to go.
The Led can be fitted in the magnet hole, but I decided to remove it from it's small pcb and mount it directly to the main control board. I then bent it through a right angle, drilled hole just behind the magnet and it all went in very nicely.
eat solution.
Richard
Richard - Did you ever find that your LED was too far back from the guide blade using this method? I have a fly GT40 that had the LED in roughly the same place, and on occassions when going really fast, the flipper doesn't flip quick enough. Pre chipped cars have the LED literally just behind the guide blade.
Jude
RichG
post 14 Feb 2006, 16:45
Post #177
Slot Guru
Group Icon
Group: PLUS+
I have found it fine, track not that large though. If Doing it again I would use the magnet hole & leave the led on the wires.
PM me for PB-Pro & S-H Power Upgrade. SSD Aux C7030 & C7042 (FTDI) USB leads
Ninco & Carrera D-132 (FTDI) USB leads, SSD Lap Display & Pit-Pro available to order
JudeSudbury
post 14 Feb 2006, 16:50
Post #178
Learner Driver
Group: Members
But still use the saloon chip mounted in front of the driver?
RichG
post 14 Feb 2006, 17:00
Post #179
Slot Guru
Group Icon
Group: PLUS+
Yes same position for the board. Fit's well and keeps the Green & Yellow leads short. You can use all the board mounted leads without extending. I have a preference for the saloon board as it is less prone to interference.
slot king
post 14 Feb 2006, 20:53
Post #180
Team Owner
Group: Members
bleep: I'm trying a scaley Opel Vectra.Using a saloon chip but now I'm to busy to finish it.I cant do pics because the camera is down.
Regards,
Ben
Ian B
post 14 Feb 2006, 21:07
Post #181
Ian
Group Icon
Group: Admin
No Rush Mate! Thats one thing I have learnt when chipping take your time! biggrin.gif
Ian B
slot king
post 16 Feb 2006, 18:08
Post #182
Team Owner
Group: Members
Problems have arisen for me.Chipped the car (unknowing the chip was upside down)Drove the car and the chip went up in smoke.Oooops
Regards,
Ben
0 Members:
   Lo-Fi Version Time is now: 25th May 2013 - 21:59
