18 Pages V  < 1 2 3 4 > »
> Slot forum test track...., A way to compare the cars we own?
diegu
post 1 May 2010, 18:01
Post #16
Top Tuner
Group: Members
Hi all,
I agree, a bridge does not add to it and makes it more difficult to compare lap times.
I would like to suggest the following layout:
Size for Ninco (Scaley should be a bit smaller): 2.84mx1.32m
Track length of inner lane: 11,37m
Racing is done on the inner lane
Pros (imho):
- Should suite at least Scaley, Ninco, SCX
- No crossing
- Mostly, inner lane is used - not many borders required
- R1 is taken on the outside as the inner lane is too tight in my opinion, therefore outer borders are added there.
- R1, R2, R3 included
- If required, size can be reduced by removing straight pieces from the horizontal straights.
- Change-over for (simple) handling test
Cons:
- No chicane
BTW: Anyone here who would like to do that for Ninco?
Regards,
Diegu
Diegu
Go to the top of the page
Slotrace.dk
post 1 May 2010, 18:07
Post #17
René 'Vialli' Christensen
Group: Members
Not everybody has the R3.
IMO you should keep it with R2 as that's what comes with a starter set.
kind regards
René Christensen
Cars on canvas
Koala2
post 1 May 2010, 21:33
Post #18
Top Tuner
Group: Members
I'm one of the R3-less homeracers.
Therefore an idea to run maximum inside lane without 90° crossing (I have one but, as stated not everyone has it).
Not finalised, only to show that with the (sport crossing R2 90°) you can also run more inside line on one of the lanes.
Oh, yes, I'm using the Carrera electronic lapcounter that measures accurately to 100 of a sec an never fails.
(I did put a scaley sticker over the brand name biggrin.gif )
Testlane would be lane 1.
davekp
post 1 May 2010, 23:00
Post #19
David K Phillipson
Group Icon
Group: Moderators
heres my twopenny worth
inside track for 19 corner sections out of 28
JL-F1
post 3 May 2010, 17:01
Post #20
Top Tuner
Group Icon
Group: PLUS+
we should do track pieces all the track types have, for instance us ssd guys have no straight lane crossover( yes I know adapters, I have that in my pits smile.gif)
are we talking constant throttle timing, I hope?
Scalextric Digital Track
Pb-Pro SH - Pyramid 32amp PS
Pit-Pro - RichG Lap Tower - SSDC
justDave
post 3 May 2010, 21:47
Post #21
David Collins
Group Icon
Group: PLUS+
I like diegu's layout, very simple and practical. But as it's a test track I would use just one crossover so that you effectively have times over two laps.
AAWSCC
post 3 May 2010, 22:07
Post #22
Team Owner
Group Icon
Group: PLUS+
Apart from the Argos sets, I only have Ninco track and no crossovers. I think standard track pieces makes it easier for everyone to join in.
But once details are sorted i'm game.
The trouble with these Chinese slotcars is that you get one, and an hour later you fancy another one.
3 lane routed track
Let's have a go at a rally track.
www.circuitstoscale.co.uk
hankscorpio
post 3 May 2010, 22:16
Post #23
42 Yrs
Group Icon
Group: PLUS+
This crossover thing has me bugged...
bridges are tough to compare...
flat crossings brand dependant...
Scalextric has curved lane crossovers...
Other brands have straight ones...
I think reducing borders to a minimum and innner lane running is a good idea for no mag...
No wonder this has never reached fruition... so if we rule those pieces out anybody want to mod their own track designs and else want to drop one in...
hankscorpio
post 3 May 2010, 22:59
Post #24
42 Yrs
Group Icon
Group: PLUS+
Twist on tracks already suggested... All R2's for what its worth...
JL-F1
post 3 May 2010, 23:49
Post #25
Top Tuner
Group Icon
Group: PLUS+
I'd be curious to see the lane length differences when you build it with ninco or carrera parts in the planner
don't we want it so the whole lap is inside lane? that's why I was thinking flat oval.
distantkiwi
post 4 May 2010, 00:21
Post #26
Trevor Gordon
Group: Members
Oval sounds good, and we can all make one, I think the only issue that it doesn't cover is how well the cars handle turning in both directions. maybe a square with s's instead of straights on 2 sides and striaghts on the other 2 sides?
Ember
post 4 May 2010, 02:49
Post #27
Group: Members
Sorry for dropping in here but, while an oval is something everyone can build, I see a problem/failing with the idea.
Surely if the point is to test handling of cars you'll be wanting some areas of rapid direction change, be it esses or full on chicane or a 'hammerhead' corner. This will test tip and roll points on the car. Will also further test rear grip and containment.
Alas, I don't have the leftover bits or room on the floor to consider joining in on the testing. But good luck with the project fellas.
Embs
Anorak. Not just a fashion statement. It's a state of mind
TINY TYERS TARGA: The saga continuesAn old shed for my new cars: An old wooden garage under construction
MrFlippant
post 4 May 2010, 03:37
Post #28
LABATYD
Group: Members
So... the first thing that's popped into my head is that, since the whole point appears to be to post data about different cars so that people can know how it competes before they get one, or to compare different setups and such, or even compete, there MUST be at least some semblance of a common, known track. Not just the layout, but the type. Even those of us who only ever race on one type know that other types drive differently. The same layout in Scaley Classic and Sport will drive completely differently, not to mention Ninco or Carrera. Unless the track is the same type from result to result, then the results are meaningless, at least until the available results are complete enough to include multiple surfaces as well as cars.
I'd love to participate, or to find other people's results useful, but I would only be able to share results on Scaley Sport, and would only pay attention to results for Scaley Sport.
As far as layout design goes, I think it needs to be small and simple. Something that would come as a set and be likely to be easily made using spare track. It's only recently that I even have what I would call "spare" track, as pretty much every piece I owned was on my table layout. If it's a design that's common to sets, then someone who didn't already have spare track, or who ran on wood, but still wanted to participate, could pick up a set (like that cheap one recently acquired by many which then spawned this thread, I think).
|}>- The Magic of INOX MX3 as a braid/rail conditioner and how to apply it.
|}>- My Scalextric Digital APB Instructional Videos
|}>- Rainier Raceways is my home track
|}>- SSD EXTREEEM!! showcase video
|}>- My local digital club, DRAWW
|}>- Swing by for a quick chat on my LIVE CHAT page.
distantkiwi
post 4 May 2010, 12:27
Post #29
Trevor Gordon
Group: Members
Correct me if I am wrong, but the aim is to end up with a list of cars so one can see (in order of importance)...
a. Which cars can race against which in a fair fight (so I don't need to buy 4-6 of every type of car)
b. the best a car can go with normal tuning (so I know what to aim for when tuning my cars)
c. lap times to beat (so I have something to aim for again)
d. the best a car can go with extraordinary tuning (so I can be impressed by what you fellas can do)
How about this?
or this
come on, surely this is the one!!!
Jaak
post 4 May 2010, 12:40
Post #30
Slot-A-Holic
Group: Members
I would go for our Distant kiwi friend option Nr 1.
THINGIEPHILE REBEL EXTRAORDINAIRE
0 Members:
Lo-Fi Version Time is now: 25th May 2013 - 17:10
