> SlotForum News Section - Please read!
NOTE: New posts in this News Section can only be added by forum Administrators and Moderators.
If you have a News story, relating to Slotcar industry news, then please send us a press release together with photos by email to: admin@slotforum.com
SlotForum Administration retain full editorial control over the content published here and will edit or remove material if we deem it appropriate to do so as it is displayed on the Front Page of the Forum and is automatically linked to by other Internet Slotcar Forums via RSS feeds.
3 Pages V  < 1 2 3 >
> MB SLOT product news
MB SLOT
post 1 Oct 2010, 17:09
Post #16
Tea Boy
Group: Members
NINCO chassis with spare parts MB SLOT
Marco Ballardini
MB SLOT
Go to the top of the page
MB SLOT
post 1 Oct 2010, 17:13
Post #17
Tea Boy
Group: Members
advice try, Art 09030, looking, look the same, but the track makes the difference
Marco Ballardini
MB SLOT
capnfutile
post 1 Oct 2010, 20:02
Post #18
Slothead
Group: Members
My hat is off to MB Slot for bringing this stuff to market. As someone who has operated a CNC lathe, I really appreciate how challenging it is to make some of this stuff. The wheels really take the "Lotus theory" to the limit. Hopefully they'll take a shunt or two.
Not sold on the spring steel contacts, though it's an interesting concept. It may be a bit like making brake pads too hard and wearing out the rotors as a result. Time will tell.
Lytle
post 2 Oct 2010, 04:02
Post #19
Tea Boy
Group: Members
Is there a USA distributor for MB Slot?
FZSsemans®
post 2 Oct 2010, 10:37
Post #20
Peter Rondel
Group Icon
Group: PLUS+
QUOTE (Lytle @ 2 Oct 2010, 05:02) *
MB SLOT
post 2 Oct 2010, 19:01
Post #21
Tea Boy
Group: Members
I'm looking for distributor in USA.
Marco Ballardini
MB SLOT
chenglaw
post 3 Oct 2010, 04:16
Post #22
Trackhead
Group: Members
QUOTE (SKYWAY @ 1 Oct 2010, 07:12) *
The new braid,sorry pickups look very interesting indeed. Never seen anything like that before ohmy.gif Cant wait to try em tongue.gif
When I got into slots back in 1963, I ordered a bunch of guides direct from MRRC and this was what I got:
The pickups were thin copper?/phosphorous bronze? and were a little stiff which was why I didn't use them.
Not too sure if this modern MB Slot gizmo is going to be any better.
Lim
I race for fun, so I usually finish last, if I finish at all!
Graham Lane
post 3 Oct 2010, 05:17
Post #23
Real name: Graham Lane
Group Icon
Group: PLUS+
There must be a reason behind the steel pickup plates. I have a few questions:
Do braids really get time to flex when a car is travelling at high speed?
Would spring steel really wear the surface of the rails?
How much longer would they last? A 24 hour race would be long enough for me!
Do they get dirtier quicker?
Have there been any trials of spring steel plates, and if so what are the pros and cons?
I curve my braids a little in a convex then tip the end down slightly. I then get two contact points. Would that work with spring steel?
MB Slot products seem well thought out, if a little fragile at times, so I would expect this to be the way forward if it's allowed at championship races.
MB SLOT
post 3 Oct 2010, 09:00
Post #24
Tea Boy
Group: Members
phosphorous bronze NO GOOD
Marco Ballardini
MB SLOT
MB SLOT
post 3 Oct 2010, 09:29
Post #25
Tea Boy
Group: Members
The old braid are soft or hard, not elastic. new braid are elastic.
SLOT CARS with a new braid takes less than jump. you have the feeling that floats. Of course we must give the right angle to the braid.
Do braids really get time to flex when a car is travelling at high speed? I do not understand
If I run a 24 hour non-use 0.05 mm, 0.08 mm or 0.10
To ensure durability to clean, tire change, with film of oil. Friction consumes braid.
Do they get dirtier quicker? After a round shape is a black line at the point of contact. Qusto helps to check whether contact is good. But I have no problem with electricity.
At the first assembly of the braid will be cleaned of dirt work.
Yes, for one year.
The braid should bend and not break.
The braid must always be flexible to ensure good contact. Car light thin braid, braid thicker heavier car.
PRO:
cars lower forward - 0.2 mm
easy to drive
fluency
amount of electricity
WITH:
are to be bent
A traditional braid can never work as a flexible steel braid, because it is not elastic.
If I use a traditional braid very thin and soft, does not retain the shape for a long time. if I use a braid that retains its shape for some time, I have a very high brush.
New brushes and new wheels, are in no way fragile.
The brushes are free today in the regulations, if MB SLOT produces a brush because it should not be approved?
Marco Ballardini
MB SLOT
Graham Lane
post 3 Oct 2010, 10:07
Post #26
Group Icon
Group: PLUS+
Thanks for the reply MB Slot.
First we must think of a new name for your 'braids' as they are not braided and using the same name leads to confusion.
When a car moves along the track the traditional braids flex to follow the shape of the rail and the joins between the track pieces. My question is 'Os it possible for a traditional braid to flex quickly enough?' If not then your 'plates' would not be at a disadvantage.
I would seriously like to try a pair of these on my NSR Mosler. Would you like a review?
sacesta
post 3 Oct 2010, 12:36
Post #27
Team Owner
Group: Members
Pickups?
Camber
post 3 Oct 2010, 12:43
Post #28
Top Tuner
Group Icon
Group: PLUS+
QUOTE (Graham Lane @ 3 Oct 2010, 15:17) *
If you have ever tried to cut spring steel you would realise how hard it is.
Wear the surface of the rails...almost certainly.
- Cam
Graham Lane
post 3 Oct 2010, 12:57
Post #29
Group Icon
Group: PLUS+
I don't see why Camber, after all it's a bit like a ski. So long as the surface is not abrasive and the edges are not sharp there should be no wear.
I just wonder how much actual surfce area of a braid is in contact with the rail on average. Very little I would think. These plates should do better.
Anyway, I'd like to try them.
MB SLOT
post 3 Oct 2010, 16:18
Post #30
Tea Boy
Group: Members
Let's talk about 0.05 mm 0.08 mm and 0.10 mm are cut with scissors.
A single strand of a traditional braid is 0.07 mm
Marco Ballardini
MB SLOT
3 Pages V  < 1 2 3 >
0 Members:
   Lo-Fi Version Time is now: 20th May 2013 - 14:51
