2 Pages V   1 2 >
> CLC not working with particular car
mikebagwell
post 20 Jun 2012, 22:30
Post #1
Tea Boy
Group: Members
I've tried searching, but I haven't managed to find anything.
I've just put digital chips into a couple of Scalextric Porsche RS Spyders. I'm having trouble with one of them where on a particular CLC it's only intermittently changing lane. Sometimes it's fine, especially if I go over the other sensor slowly, but sometimes it doesn't work - the flipper will just stay where it is as the car approaches - if the flipper's already set to change lane the car will change uncommanded, and if it's set to straight ahead the car will carry on when the lane change button is pressed. As I said, it works fairly consistency at low speed, but at racing speed it's much more tempermental. I've tried changing the chip and I get the same behaviour, but only in this one car. The other RS Spyder is fine, and this only happens with one of my CLCs - I have another CLC and an XLC which the car is fine with. The CLC in question works perfectly fine with other cars, and it has the 'dimple' in it to prevent the guide crashing into the flipper. I can't see anything obviously wrong with the guide or the underside of the car, so I'm really confused!
So I was just wondering if there was anything you could suggest I look for?
Mike
Go to the top of the page
Michael363672
post 20 Jun 2012, 23:11
Post #2
Sir Slotalot
Group Icon
Group: PLUS+
How are you getting to the sensor track ?
ie does it have a full straight before it ?
Does the car slide and thus miss the sensor at race speed ?
Also give the sensor a blow out just to make sure there is no dust on it
Michael
Don't Forget That I Finish Last ....... I Am The Best At Being Worst
Have A Look Here For Great Slot Racing
LEFT TURN DIGITAL RACING IN ESSEX
UshCha
post 21 Jun 2012, 05:48
Post #3
Trackhead
Group: Members
Is it a DPR or soldered in chip. Anyway the only thing I can add is is the position of the sensor EXACTLY in the same position in the offending car. If it is not than that may be the problem. It suggests that for some reason, proably missalighment of the car instalation as all chis are as bad, the CLC and car are not getting a good look at each other. Thats all I can add to Michaels comment.
57 yr old Newbie
SSD Rug Racer
Derby UK
Ade
post 21 Jun 2012, 06:20
Post #4
Digital=Realism
Group Icon
Group: PLUS+
hi
the usual culprit for random operation is dust. Give the clc a vacum witha soft brush attached and make sure the optical senser in the car is also dust free.
There have been the odd occasion where the chip senser has been obscured with a smear of glue from the factory.
Depending on location it is always a good idea to hoover the track every couple of weeks to ensure reliable
and smooth running.
mikebagwell
post 21 Jun 2012, 22:24
Post #5
Tea Boy
Group: Members
Thanks for the suggestions. To answer the questions - it's a DPR chip. Both the ones I've tried are Rev G chips. As for placement, the senso does appear to be in exacatly the same place in both the working and faulty RS Spyder, so I'm baffled!
The CLC is after a corner, but the car doesn't slide out at full speed as it has such strong magnets, and it's the only car that seems to have an issue with the sensor coming after a corner. I tried moving the CLC to the end of a straight, and while the car was a bit better at changing lane, it still failed to change now and then.
I've hoovered the track and checked both the track and car for devirs/dust etc, and everthing looks clear.
It's a mystery!
Michael363672
post 21 Jun 2012, 23:05
Post #6
Sir Slotalot
Group Icon
Group: PLUS+
What happens if you put that chip in another car ??
Mr Modifier
post 22 Jun 2012, 07:53
Post #7
Circuit Owner
Group Icon
Group: PLUS+
You could try:
1) Swapping chips across as Michael suggested - if it's a dodgy chip it will make the other car exhibit the problems
2) Swapping magnets - even in identical cars there are always differences in motor power and traction magnet strength due to manfacturing tolerances. It could be the magnet in your troublesome car is weaker - this would allow it to slide more than the other car and miss the sensor more often.
My money is on the troublesome car sliding more than you think it does. Even the most powerful magnets allow a car to slide and the LED only has to be 3mm off to the side to miss the sensor.
I have this problem occasionally on my track - the pit lane entry is a half straight after the exit from an "S" bend made from r2 pieces and occasionally at racing speed some of my super resistant cars with magnets will miss the sensor which means the car follows the lane changer to whatever it was last set to - and sometimes that means a full speed entry to the pits!
Once you have proven it is the magnet then your only options are to:
1) get stronger magnets
2) get stickier tyres (or clean and treat the ones you have)
3) place the CLC so there is a long straight to tidy up the car's position before it passes over your sensor piece.
mikebagwell
post 22 Jun 2012, 20:48
Post #8
Tea Boy
Group: Members
Thanks again for all your help.
I've tried swapping chips - this is the second chip that exhibits this behaviour in this car. The first chip is now in aother car and is absolutely fine. So I'm reasonably confident it's not the chip.
Magnets - strangely enough, of my two Porsche RS Spyders, the faulty one has by far and away the stongest magnet. In fact, it has just about the strongest magnet of any Scalextric car I own - it's able to go flat out through about 80% of my track. I also tried to eliminate sliding as a factor when I moved the CLC to the end of straight by ensuring the car was nice and straight and then accelerating towards the sensor. Although the car was fine initially, after a while it stopped changing lanes again. Is it possible that the magnet is too stong? Perhpas it's lifting the front of the car away from the sensor? I know it sounds daft, but this flippin' car has defied all your other suggestions so far!
I'm beginning to think I'm just going to have to accept that this an unsolveable mystery and I'll have to just put up with slowing down a bit for that particular CLC with this car.
Oh well!
Mike
Michael363672
post 22 Jun 2012, 20:55
Post #9
Sir Slotalot
Group Icon
Group: PLUS+
Take the front tyres off and run it around see if that makes a difference
If it does then the front could well be to high and the beam may not get the full effect
q-man
post 23 Jun 2012, 07:50
Post #10
Learner Driver
Group: Members
I have had problems with few cars and few of them are lmp prototypes. I believe its wheelbase related. Spyder has maybe longest wheelbase that 1/32 will have. Of course DIY chipped cars may have led located too far back so led "travels" of rails on corners.
GregK
post 23 Jun 2012, 09:17
Post #11
Magic Smoke Restoration Club Member
Group Icon
Group: PLUS+
Flog the Devil Car on the bay and buy a new one that works ......... smile.gif
Beauty is in the eye of the beer holder
sealevel
post 24 Jun 2012, 17:27
Post #12
Sir Slotalot
Group: Members
Have you tried moving/extending the LED closer to the pickup plate? I have read that some people do this using the flying LED lead on the non-DPR chips.
Just a thought.
Cheers!
My 4x12 layout | Track Categories | Digital/Sport PB wiring | Track cleaning vehicles
Modular layouts |Throttle Holders | PB-Pro separation | Rivets for barriers
----- PB-Pro+SH, SSDC, RichG Lap Tower, Pit-Pro ----- (Track still under development) -----
"analysis paralysis" - inability to make a decision after extensive data gathering & evaluation.
mikebagwell
post 24 Jun 2012, 20:29
Post #13
Tea Boy
Group: Members
It's a DPR car so I don't think I have much choice over the location of the LED.
I haven't tried running it without the front tyres, but I think I'll take GregK's advice and get rid of it - although I'm a bit more fond of it now it's been termed the Devil Car!
Thanks again for all of your suggestions!
Mike
GregK
post 24 Jun 2012, 21:45
Post #14
Group Icon
Group: PLUS+
Is the Devil Car only misbehaving on the one CLC or is this behaviour exhibited on other changers?
mikebagwell
post 24 Jun 2012, 23:24
Post #15
Tea Boy
Group: Members
Yes it's only misbehaving on one, and as Michael363672 suggested, it's the only CLC where the sensor is straight after a corner.
But when I moved that particular CLC to the end of a straight it only partially fixed the problem with the car. Which leads me to think that some sort of unique combination of that particular CLC with that particular car is the problem, but nothing so far suggested has worked, so I'm completely confused.
I'll probably hang on to the Devil Car, as it works fine as a pace car, so all is not lost!
2 Pages V   1 2 >
0 Members:
   Lo-Fi Version Time is now: 19th June 2013 - 15:55
