> Lexan Body Repair
kazooracer
post 29 Jul 2012, 05:48
Post #1
Newbie
Group: Members
Hi all. Long time lurker, just started posting recently.
I've raced modern 1/24 cars for about 4 years now and I am just getting into the vintage scene. I've picked up a few cars that have lexan bodies that are for the most part intact, with maybe one of two small (less than 1/4") tears in them. What are the popular methods for making a repair? For my regular race cars, I'd use a nylon packing tape, but considering that these bodies are 40 years old with 40 year old paint, I'm curious if there's a better way to fix the tears.
I did a seach on the topic and didn't see anything posted already, but if I missed something existing I'm sorry for the exta post.
Go to the top of the page
Bigtone
post 29 Jul 2012, 06:53
Post #2
Tony
Group Icon
Group: PLUS+
You can buy self adhesive lexan strips to reinforce the inside of the bodyshell, several companies make them but I use Parma
Tony
I'm Feeling Comfortably Numb
PETER GUNN
post 29 Jul 2012, 07:02
Post #3
Racer Dude
Group: Members
Morning Kazooracer, bigtone is right about this tape it is reinforced and i have been using this type for nearly 50 years and my anglia from 1968 is still with us due to this tape, the last lot i bought was from S,C,D Chas Keelings place in Bradford, try S,C,D Homepage on line and see his lists Cheers Keith.
K F WELLS
stoner
post 29 Jul 2012, 09:00
Post #4
Team Owner
Group: Members
I use the nylon strapping for the sides of the body where the pins go. it adds tremendous strength to the shell. I never knew they did self adhesive lexan. Ive got a few shells that need repairing and this sounds just the ticket, funny how you never stop learning. john
dgersh
post 29 Jul 2012, 10:14
Post #5
Don Siegel
Group Icon
Group: Moderators
Kazoo,
The other thing is, are these shells really Lexan? Before 1970 or so, there's a chance they'd be in butyrate, a different material: that would apply to all the Lancer, Russkit and other clear bodies of the time.
For these bodies, if it's a clean split, I use either "crystal" clear, fast-setting epoxy, or Ambroid Pro-Weld. Lexan would probably need its own type of glue. And the self-adhesive strips sound good too - had never heard of these either.
lowrider
post 29 Jul 2012, 10:28
Post #6
Slot Guru
Group: Members
They're sold as 'body armour' from a few sites, Don. The Parma stuff is as good as any other.
I was about to remark on the likelihood that 40 year old bodies were not actually Lexan. Another side of this is that without the self-etching properties of modern polycarbonate specific paints, the strong adhesive employed on body armour might well pull some of the vintage paint away before it reinforced the body split.
Don's glue suggestions might be the best way forward.
Regards,
L.
JOHN SECCHI
post 29 Jul 2012, 11:17
Post #7
John Secchi
Group: Members
If the body is not for serious use but to be kept as an original I have used a hot glue gun with good results.
Works well for splits in corners on either butyrate or polycarbonate [not the silly thin fag paper ones though] , lay a bead of hot glue then wait a few seconds then smear the bead over the split with your finger, a good resistance to pain is a help!
Holds quite well as its a flexible repair, however make sure the paint is well keyed to the surface or the glue will peal off with the paint.
Good luck.
[oneofwos]
kazooracer
post 30 Jul 2012, 02:14
Post #8
Newbie
Group: Members
Again, my lack of knowledge led me to incorrectly describe the bodies as being made of lexan when they really are made of a much thicker but still clear material. So butyrate is the correct term?
I do use nylon strapping tape on my modern cars to reinforce the pin holes but was concerned over using it on 40 year old paint, but once I've touched up the paint on one of the bodies I'll give it a shot. I do have one local hobby shop that deals in R/C and will give them a check this week to see if they have the lexan tape that was mentioned. But I do have one crack in a corner that I think the hot glue suggestion will be better suited for.
Thanks to all who responded to my request for help. I can see that I'll be hanging out here more in the future. biggrin.gif
bill from nh
post 30 Jul 2012, 02:57
Post #9
Tea Boy
Group: Members
You could also use a product called Shoe Goo to reinfore the cracked areas. It's a rubber type material, similar to silicone caulk, that remains flexible when dry. Tubes of it will be found in some shoe stores, some hardware stores, & online places such as Amazon. A large tube will cost $5-6. smile.gif
Bigtone
post 30 Jul 2012, 09:54
Post #10
Tony
Group Icon
Group: PLUS+
The self adhesive lexan I mentioned isn't a reinforced tape it is completely clear and comes in strips see link http://www.chaskeelingscd.co.uk/accessories.htm. I use it to reinforce pinholes and the noses on F1 cars, you can also bend it to right angles to reinforce or repair corners of bodies
janj86
post 2 Aug 2012, 19:55
Post #11
Slothead
Group: Members
shoegoo if you dont mindit being a little thick
still trying after all these years ....
0 Members:
Lo-Fi Version Time is now: 19th June 2013 - 02:45
