Jump to content
Slot.it News - Matra-Simca MS 670B
  • Please log in to reply
20 replies to this topic
#1 JEXY1
JEXY1
    Gareth Jex
  • PLUS+
  • 4,212 posts
Posted 05 March 2014 - 06:02 PM
Slot.it News;
Matra-Simca MS 670 B - #8 Le Mans 1974
Drivers: B.Wollek, J.-P. Jaussaud, J. Dolhem
Code: CA27a
Official selling date: March the 20th
The Matra-Simca MS 670 was a Prototype race car that won the Le Mans 24 Hours 3 times in a row (from 1972 to 1974) as well as the World Manufacturers Championship twice (1973 and 1974).
The car was designed by Bernard Boyer and Jean-Louis Caussin. The long tail version, designed in '74 for Le Mans, was still called '670 B', 'B' being the distinctive letter of all Matras that were fitted with the Porsche 5-speeds gearbox.
The chassis was an aluminium monocoque, with fiberglass body. The engine was a 3-litres V12 at 60°, with aluminium block and head; bore was 79.7 mm and stroke 50.0 mm. Its sound was extremely loud.The version used in '74 for Le Mans was the 'MS 73', with a maximum torque of 320 Nm at 8400 rpm , reaching a maximum power of 450 HP at 10500 rpm. On the Mulsanne straight the car could top 320 kph. Brakes had Girling ventilated discs, all-round; in 1974, the rear brakes were moved inboard. Rims dimensions were 13” x 11” at front and 15” x 15” at rear.The car weighted 693 kg.
There were three '670 B's racing in Le Mans in 1974. Number 8 was driven by Jean-Pierre Jaussaud, Bob Wollek and José Dolhem.
Images and text as supplied by Slot.it
Posted Image
#2 PJF
PJF
    Trackhead
  • PLUS+
  • 917 posts
Posted 05 March 2014 - 06:46 PM
Anyone know if its inline etc, & can it be AW ?.
Its top of my shopping list for Gaydon.
Paul.
Tyneside slot car club, Unit 12, Helmsman House, Chirton Ind Est, Newcastle Upon Tyne, NE29 8RZ www.tynesideslotcarclub.com
#3 ggonsalves
ggonsalves
    Learner Driver
  • Members
  • PipPipPip
  • 91 posts
Posted 05 March 2014 - 07:04 PM
Paul its a sidewinder.
#4 Slotcarmann
Slotcarmann
    Dave Capelen
  • PLUS+
  • 2,514 posts
Posted 05 March 2014 - 07:19 PM
#5 ferraif40
ferraif40
    Jon Grainger
  • PLUS+
  • 3,811 posts
Posted 07 March 2014 - 01:39 PM
Maurizio, what are the dimensions of the model for scale racing?
#6 Guest_Henk_*
Guest_Henk_*
  • Guests
Posted 08 March 2014 - 07:19 AM
"Gitanes, cigarettes de France"
I wonder if this car will be available in countries where there is a ban on advertising tobacco products question.gif
I remember well that the first "Silk Cut" Jaguars had removable decals over the advertising.
#7 PJF
PJF
    Trackhead
  • PLUS+
  • 917 posts
Posted 08 March 2014 - 09:18 AM
QUOTE (Henk @ 8 Mar 2014, 07:19) <{POST_SNAPBACK}>
I think it should be ok, the avant slot Renault Alpine A310 came with the Gitanes logo !
Paul.
#8 slotcrazy
slotcrazy
    Trackhead
  • Members
  • PipPipPipPipPipPipPip
  • 687 posts
Posted 11 March 2014 - 04:33 AM
No one in Kiwiland says "pass me a gitane", so I think we're okay down here smile.gif
#9 slotcrazy
slotcrazy
    Trackhead
  • Members
  • 687 posts
Posted 16 March 2014 - 01:51 AM
IMPOSSIBLE, or as the French would say il n'est pas possible
One privilege of being a distributor, is having access to new models before the general public. In the case of the Slot.it Matra, it has been sitting festering, calling to me from the work table, so today I decided to open one up and see what this little frog car, this "Simca" could do.
First glance showed me it has a wheelbase several mm longer than the McLaren and GT40, less guide-lead, (the length the guide is in front of the front axle), and more plastic behind the rear axle for "pendulum" weight. None of these made for a very promising performance.
First up, I just flattened and flared the stiff standard braid, loosened all 6 pod and both body screws 2 fulls turns, and threw it on the track, stock tyres, nothing glued, nothing trued; - and quickly got down to 5.65 seconds, which is anything but shabby on my track.
WRONG, OH So wrong, wrong, wrong wrong, wrong, wrong wrong, wrong, wrong wrong, the Maurizios' strike again
Back to the bench, swapped the rears for some glued and trued N22 rubber from a Group C Sauber, removed the "choke" from the motor in case it was fouling the underside of the body, adjusted the pod float a little, and back to track.
5.45 without trying hard, and it was wheel-standing out of the slot under acceleration out of the hairpin, smooth as butter.
Back to the bench
Trued the front tyres - didn't bother to glue on for a quick test. Added 4 grams lead to the chassis between the front of the pod and the body post, and moved the magnet to the front position in the pod - just to trim the forward weight balance.
Removed the front axle stoppers, fitted grub screws underneath and set the front ride height for full guide depth.
Back to the track
Better balance, and quicker, 5.3 . . .5.2 . . . 5.1 5.1 5.1 . .
Nope, not possible.... stopped to check the timing system.
5.2 mistake and a 5.3 as it came out of the last corner on the outside 2 wheels, guide airborne and dropped back into the slot. 5.28 5.16 5.11
Note. The car hasn't been disassembled since the factory, the chassis hasn't been flattened... nothing fancy....
For those of you who don't know my track, is a 64 foot (19.5 metre) wood routed track, tinned-copper braided with 8 turns. No magnetic effect.
The longest straight is 3.2 metres, and the next longest is just 2.2 metres.
Anything that can do around 5 seconds for 12.5 feet average speed per lap is bordering on qualifying for the 100 metres at the next Olympics.
Oh my.... I have a new favourite.
#10 Pete-slot
Pete-slot
    Trackhead
  • Members
  • 711 posts
Posted 16 March 2014 - 07:09 AM
I spoke to Tony at Pendle yesterday (Saturday)... said they would be in stock in the UK
tomorrow (Monday).
it looks good, .... how did they get around the cigarette advertising ban ?
170 FT of 6 lane NINCO on your doorstep!
5 minutes from Hampton Court - West Molesey, Surrey KT8 2LG
#11 Kit Spackman
Kit Spackman
    Team Owner
  • Members
  • PipPipPipPipPipPipPipPip
  • 1,035 posts
Posted 16 March 2014 - 07:37 AM
As your track has no magnetic effect do you use the magnet on the car a moveable ballast weight then?
Kit
#12 Pete-slot
Pete-slot
    Trackhead
  • Members
  • 711 posts
Posted 16 March 2014 - 07:38 AM
looks like mag braid to me
#13 munter
munter
    re member
  • Moderators
  • 2,257 posts
Posted 16 March 2014 - 08:38 AM
I have run on that track...it is not mag braid....3/16 tinned copper
slotcars are my preferred reality
#14 Kit Spackman
Kit Spackman
    Team Owner
  • Members
  • 1,035 posts
Posted 16 March 2014 - 03:26 PM
He says 'no magnetic effect'............
Kit
#15 GregK
GregK
    Greg Kilkenny
  • PLUS+
  • 7,824 posts
Posted 16 March 2014 - 03:56 PM
QUOTE
Slot.It cars are not sold as "toys" so the ban does not affect them; children under 14 won't be buying them ...... smile.gif
