Hi Guys
As you may have seen in my Brands Hatch build thread I have been making and printing some 3D figures, I'm hoping I can make an easy way for others to do this as unfortunately the EULA of the software I use precludes me from sharing my files theselves.
Figures currently take about 6-7g of PLA to print (approx 150 figures for a 1kg reel which works out about 10p ea)
They take around 1.5-3.5 hours per figure to print at 0.1mm layer thickness.
First of all you will need some software... don't worry it's free, though if one wants to expand the possibilities (I.e. wardrobe and accessories) extra content is required and that can cost though much can also be acquired free if one is prepared to search and to experiment with positioning of objects.
So lets start...DAZ3D... this is where I build my 3D character models
You will need to sign up to DAZ
https://www.daz3d.com/customer/account/create/
Once you have done that it should open a popup to download software... this is the Install manager it helps you download and install software and content and I find it very helpful to keep track of what has been downloaded and installed.
Once the install manager has been installed you can allow it to run, you can run it online or offline. You'll need to be online to download unless you have already downloaded the files.
Once you have got into the installer you will see a long list of content that you have free. From this you can choose what to download.
I would suggest what I have ticked is a good starting point.
You need the DAZ software itself.
Genesis 2-4 are the figures.... so you need them
dforce allows you to drape clothes, I strongly recommend that too.
I do not think you need the Poser components but you may choose to download them.
I am also uncertain what the 3D print components are, I don't use them.
I have ticked what I think is a good minimum starting point you may wish to add other components.
The DAZ3d promo image shows the Newport outfit for example, which is included.
Then Start the queue to let the software download you can install.
I'm finishing the post with an image I created in DAZ and 2 of my 3D printed figures from DAZ3D models
