The second version of my permanent track ultimately proved unsatisfactory to me because the plastic track didn't provide a suitable surface for tuning my cars for club racing on routed wood tracks:
The basic layout seemed to work very well in the space I had available. I liked the two levels, and it divides well into four "zones" to give opportunities for scenery. However I didn't like the left-hand "finger" as it was hard to see when two people were racing at the same time, so I amended the layout:
I wanted to approximate the feel of the Rockingham Slot Car Club's 1/32 scale track as much as possible, so I decided to use non-magnetic braid and the same track paint as we use at Rockingham. But I didn't want the track to feel too geometrical, like plastic track sections or by routing with continuous radius curves, so to enable me to take a more freehand approach in some sections I ordered the routing kit from Luf Luffenham:
So, with the basic design committed to, I gritted my teeth and ripped up the old track:
I'm generally hopeless with practical things that need some technical skill, and so I must give credit to those who have given me the confidence to start. SF member richardtheforth, sold me a good router at an excellent price, clubmate John Roche loaned me a second router, which enabled me to rout the gains for the braid without having to keep changing router settings, and I watched club mates and skilled engineers Mick Kerr and Mike Thomson routing new sections for the Rockingham scale track.
But even with their support this has taken me an awfully long time...
Firstly I modified the base boards and then bought the mdf, pre-cut from 8x4 to fit the track sections and then roughly drew the layout on the boards so I could better visualise what I wanted to achieve:
Hi John, almost finished with it now! I'm about to put down the tape and braid - hopefully I have all the depths right. Otherwise I am in shtook as you will see...
I forgot to say, the base board is 11' 6" x 3' 9", and the track will be 40' long.
What can I say about my routing experience? Rather inexperience, plus lots of mistakes, plus changes of mind (a.k.a. inadequate thought and planning). It all meant that filler and a power sander were a essential tools! But once I understood how to use Luf's router base plate, which needed holes drilling to mount it to my particular router (sorted with a very helpful email exchange with Luf) the process, using Luf's lexan guide strip was all relatively straightforward.
The track layout meant that I had to rout the sections individually and then join them only when everything was complete With most of the routing finished, the track looked like this:
And then a great day not so long ago when I finally nailed it all together:
I am aiming for a 1960's road track style, with old Scalex buildings adding a retro feel. When it's finished, I am hoping it will look like a circuit built in a disused quarry, with rock faces made using the "frock" (foam rock) technique - basically bits of foam with the surface roughed up to look like rock walls, spread with grout or similar, then painted.
The brick shed that houses my tracks is pretty primitive, but it is dry. Nevertheless I sealed all the surfaces and edges of the mdf before laying it down. I've painted with the same Sandtex paint that Rockingham used for the scale track, and I've painted the lane colours inside the slots, which I think will be perfectly OK for small home track purposes. To give myself a bit of inspiration, I roughly painted the sections that will be grass when its all finished. For the last pics, I've pulled the buildings from their dusty storage to give a sense of how the track will look when complete:
The tunnel section under the back straight will have lighting, as in the first picture in the first post, and the corner on the top left is banked.
Next phase is taping, braiding and electrics, which I am hoping to complete when I take a few days off in two weeks time...
Looks like a great track with a nice mix of different radius corners, looks like it would be a good track to race on.
Will be interested to see how you blend in the tunnel as I have a similar tunnel on my layout and I'm not entirely sure how to get it to blend in so it looks good.
I took some time off work this week, amongst other things to try to finish the track (or at least get it running). With some final prepping and cleaning of the slots done, it was time to lay the double-sided tape down:
I then pushed on with the braiding - with my back protesting more and more through the day!:
I can't tell you how good it felt to have that over with! I thought that it would take ages, but prepping, taping and braiding of the two 40-foot lanes took 6-7 hours in total.
Now it starts to feel like a proper model car track, and I couldn't help myself, I had to put some buildings and cars on to give a feel of how the finished item is going to look:
I should be able to get the wiring done tomorrow - I have a Professor Motor wiring loom from my previous track, so it should not be too difficult a job. Then there's just the business of installing barriers, and I can get to running cars on it. Landscaping can then be done at a more leisurely pace...
Thanks guys - I'm pretty pleased with how it's turning out. That's a 40 foot track length in pretty much a 12 foot by 3 foot space, but there's still enough space for an atmospheric scenic treatment I think.
A really nice track. when do you think you will have it up and running. Its a lot of work but a wood track is so much nicer to drive on. well done and I hope to see you at the club some time soon.
Thanks for the complements guys. I did the electrics yesterday to BSCRA standard, so it works with electronic controllers - though the standard Parmas are fine for this sort of layout. It's not exactly fun to drive yet - still very dusty and there is no grip laid down, but it works!
Well, Spring has sprung and the grass has riz and all that, and finally the track is taking shape - it seems like it has taken years but from the thread it looks like just about nine months - just like giving birth and about the same amount of pain I reckon....
The only barrier to racing is the lack of actual barriers!
So I looked back at the start Dave, you have come a long way and done a nice job.
Although my daughter has presented me with another grandson in shorter time, than your build, it has been worth watching the updates
The track has a nice flow to it and some good technical sections and a fast straight. All good things to incorporate.
The track will rubber in at a surprising rate once you get going.
Mine only took a couple of hundred laps per lane and the grip was there.
When cleani g the track try not to take up the rubber, just the dust.
I use a swiffer cloth and it leaves the rubber down but picks up all the bits of dust and dirt.
Looking forward to your continuing project at Olney.
Bob
Barriers going up this weekend John! Will have to have an open day sometime over the summer - mind you, the shed will only fit six people at a time!
Thanks for your comments Bob - although I had to google "swiffer"! I must say I'm not one of those people that can get as excited about cleaning as they seem to be on their website. But yes, I take your point that I will want to remove just the dust as the track gets rubbered in.
TeddyT, Rockingham is no more than an hour's drive from you, pretty much all on dual carriageway. Oxford is probably about the same in the other direction. We have routed tracks at Rockingham, Oxford is Ninco. John Underwood (zero5) races at both, so he could tell you more about the differences. But the best one is that the Scalex-type racing happens on different days of the week - Tuesday at Oxford, Thursdays at Rockingham, so you could do both, as John does!
EvadingGrid, thanks for the complements =- and no, I doubt whether it would last long outside, even with marine-grade mdf and copper braid!
Just in for a quick lunch break - more progress later!
Related Threads
SlotForum
1.3M posts
32.8K members
Since 2002
