This was the first slot car I ever built back in July of 2018. It was the prototype for everything that got built after. My first paint job too. A scary thought now.
This was the only chassis to get manufactured on a vertical mill. I couldn't take the mill home. I had to come up with a better solution to achieve the same goal.
The mill was only used to drill and ream the holes. Talk about over kill. But the digital read out was convenient.
The sides have been cut away. Please excuse the rough edges and unfinished look. I left the side plates long around the motor so I could figure out a way to screw the motor in place.
Test assembly.
Screwing the motor in seemed like a good idea. Right up until I saw the 5-minute epoxy. That should at least get me through this prototype.
Test fitting the body to the chassis.
Driver added. Fred Steinbroner, car number 18. 1950 Carrera Panamericana.
The car flipped over and off the track like mad the first 2-races. I added urethane washers between the body and chassis and started winning races. It later came back to me from another club that the car earned the nickname Lightning in the bottle. I never saw that coming or planned for it. I got lucky. It started the ball rolling for aluminum chassis.
Custom aluminum chassis. Sloting Plus roller bearings. BWA wheels (sadly no longer available. See RS Slots). DArt tires and inserts. BWMS050 motor with 10x23 gears. Professor Motor axles and wire. Slot It guide and braid.
Thank you very kindly for looking.
336 KB
231.9 KB
114.8 KB
141.9 KB
155.2 KB
231.1 KB
113.3 KB
164.8 KB
128 KB
151.3 KB
137 KB
166.4 KB
188.3 KB
172 KB
