1 - 12 of 12 Posts
Been thinking about building a 60's F1 car for Fates race but a paucity of proper bodies here is a probelm yet. So to do some practice for such small cars, I Found this old Buterate vac 1/32nd scale Indy Lotus 38 body in some old stuff given to me a few years ago. And it did not look too bad and I thought I would build up a chassis for it. It is painted on the inside with water based paints.
Its a pretty narrow small chassis to build for or to find a small enough motor to fit. The driver in this body is molded in so I was going to cut it out and fit a 3/d driver. NOT! no room when the motor goes in. I had to improvise
I had to make it an end bell drive using a Mura Endbell in a cut down Falcon can. The can was made into a strap type and the magents were not cut down any, as that setup would fit with the endbell drive. I made a small narrow brass billet axle drive housing up and soldered the main chassis chassis rails to that. The magnets were glued in the can.
It is almost finished, just a few more details like more suspension details to the rear axle area and A new vac formed windshield to be made up and fitted. As the molded in one was way to short. Also a rollbar is being made up with a rear brace.
The livery is a fantasy one as I did not want a Jim Clark duplicate so this is a supposed backup car purchased from Lotus after Clark won in 65. Been a fun project and runs very well with a Slot-It 25K arm installed in the motor. Front wheels and tires were made up and the rear tires are silicone coated sponges. Sizes are 5/16ths front by .760 Dia and rears are 7/16ths by .790 dia.
Very nice Larry. Great work, as always. Please submit an entry for the F1 proxy. I can't imagine one of these events without your handy work being featured. I'd recommend Andy at ABSlotSport or Chas Keeling for Classic fiberglass F1 bodies. I live in the U.S. and have had great success with both Andy and Chas.
Steve
That looks radical, Larry! How do the mags stay in the can? Are they glued? Is that sufficient? With the can cut away so much, I can't visualise quite what is going on in there.
Lovely job. Not underpowered, I would guess.
Russell Sheldon
Beautiful, Larry!
For a man who has made his own perfectly accurate 1/32nd scale Indy car body from styrene sheet, I didn't think that not being able to source a suitable F1 body in the 'States would hinder you!
Love that 'strap' motor? Fergy?
Kind regards
Russell
Depends on what you call a strap can I guess Fergy! Anyway here is how mine looks and was done to get some room for the neck and shoulders of the driver. And all of the motors I have on hand were much too big to allow it stock. The magnets are the Stock Falcons and are epoxied in place.
Thats why I mounted the motor endbell to the drive end. So the rear of the cut can like this cleared the driver just enough to fit.
This gives me a motor I know will run on a good 12+volts and keep on running and be re-buildable when it needs it. The car runs very well and is very drivable. It ran on our commercial 110 ft track and was turning 5.9 -6-1 laps very nicely. It weighs 89 grams and may need a touch more weight in front. But its a practice chassis, till I get a 60's F1 body located The right one should fit this chassis. Or the chassis can be made to fit without too much bother.
Larry S.
Brian Ferguson
Larry, that is a superb modification to an S-can!
And, as for those who denigrate me for my strap-motor comments.... JP
.... and Beejay
. Besides, I'm not a power-hungry guy! heehee! HaaHaaa.... bwaaa-haa-haaa-ha-haaa!
Have you tried shortening the can as well, Larry? If you knock those little tabs out, the magnets slide in a few mm further, and the little stop/washer on the arm can be moved up a similar amount. Then you can trim the endbell end of the can down and fit it all back together. I'll bet you have! Doesn't seem to affect performance. I havn't done it with a trick endbell like yours. But it's very useful in the confined space of an F1 or a narrow sidewinder.
I'd be interested to hear your ideas.
Still nervous about relying on epoxy alone to keep the mags in place, but I guess it works- doesn't it? I was idly thinking if it was worth grinding a little groove in the magnet edges so that you could slide a spring clip in there too. But I guess not.
The Mura endbell is SOOO cool though- I'm going to have to try that. If I can cure the wobble on my Unimat.....
Yes Howmet;
I have shortend the cans and have made up a bunch of these conversions over the last 6 years or so. I have a two piece brass lathe fixture I made up that fits the Mura endbell so it is centered and clamped tight while turning the endbell to fit the Slot-It or Falcon type cans.
The cans have had various and sundry magnets in them in various lengths etc. Even including a set of cobalts that were a bit of overkill for the arms used. The current epoxies are quite good and these small motors don't get hot enough to really soften them up.
I re-wind some of the arms also such as the Slot-It with the good comms and the Pla-Fits such as the new Fox and the new Cheetah II's as they have even better comms. If I am going to play around with the small motors we use mostly in 1/32nd scale I like them to be re-buildable a time or two anyway, by truing the comms when worn and adding new brushes.
Lots of fun to be had in the old shop with slot cars.
1 - 12 of 12 Posts
