1 - 20 of 22 Posts
Phil Field
Thought id post up the classes and regs for 2012.
Most are unchanged from 2011, 70's F1 is changing the most.
70's Scalextric F1.
Heres the following cars allowed:-
C12 Shadow
C25 Ferrari 312B2
C26 March 721
C50 Lotus 72
C51 BRM P160
C120 Brabham BT44b
C121 Tyrell 007
C123 Shadow
C124 Ferrari 312T
C126 Lotus 77
C127 Mclaren M23
C129 March 240
C133 Wolf WR5
C134 Renault RS01
C135 Tyrrell 008
C136 Ferrari 312T3
C137 Ligier JS11
Only Scale-auto Yellow can motors Short or long.
Slot it F22 F1 tyres only.
Fixed gear ratio 9/27.
70mm max back axle.
Ninco DTM
Same as 2011
Silver can motors only, unglued ninco tyres only.
Le-mans GT
Same as 2011
Any GT car which has raced at Le-mans. No Mosler's or P68's!
No Dodo motors. Body must cover wheels/tyres.
Ninco GT
Any Ninco GT car closed or open top. Ninco tyres only
Long can motors only.
Classic GT
Slot it or NSR classic models.
Standard gear ratio only. NSR or Slot it tyres only.
Standard motors only Slot it cars must use v3 21k, NSR cars must use Shark 20k.
SCX Rally
Any SCX rally car from classic, 80's or modern.
If i have missed anything please say!
Phil
Phil B.
How many revs do the yellow can motors have? Are we allowing sprung guides in F1 and are we running standard Scaley rear axles with the standard pinion and gear ratio and do these Slot It tyres fit Scaley hubs?
I take it that all high mag motors are banned and in Ninco GT can we have one named motor, NC5 for example.
Rally spec - which class? Classics or 80`s. Forget Modern or Modified or we`ll have an invasion of NSR GT "rally" cars.
Cheers - Phil
Phil Field
Hi Phil,
Ref F1 regs:-
The yellow cans are 25K, hardly any mag effect.
The Slot it F22 F1 tyres fit scalex hubs.
Any guide can be fitted.
We can set the gear ratio to 9z 27t?
Ref Ninco Class:-
I dont mind ref motor, trouble is NC5 isnt the standard motor anymore.
Ref Rally class :-
Thought we were going to run different class each round?
Modern is ok cos no GT cars are in this class.
Phil.
Phil B.
Tidy job
As long as we all use the same motor, not expensive and not high mag. (I used the NC5 as and example as it was the only number I could remember
I must read the Slot Rally GB rules sometime
See you thursday.
Cheers - Phil
Phil B.
Last years regs
[quote name='hotlap' date='26 Nov 2010, 17:28' post='569650']
Heres the 5 classes we are racing in 2011:-
Le mans GT.
Slot it, Ninco, Avant, MB, Fly, Spirit, SCX, Slotting Plus, Scale-Auto, Scalextric, Sloter & Pro slot.
Any GT car which has run at le mans. Classic or modern.(No Moslers)
Wheels must be under arches. No Dodo motors.
The original post omitted NSR but in posts # 7&8 the were allowed as long as the car had run at Le Mans
Hi Guys.
Got a few questions about next year.
Number of classes this year we had 5 next year showing 6, so are we dropping one round from each class or is the rally class going to be as is now ie first free Thursday of the month. Also are we going to continue rotating the classes or going back to one at a time.
F1's
Are tyres allowed to be glued?
Standard hubs or not?
Original gears or just the orignial ratio?
Ninco GT
Is this for Ninco race cars, road cars, rally cars, all?
Are we setting a Motor or open to all Ninco motors?
Rally
Are we running this on Aberstone or rally stages
Le Mans
More bit of advice this one, If I want to change the motor in my Mazda whats the best? Boxer 2? Flat 6? Also what do I need to change it to anglewinder and best gear ratio.
Sorry for asking so many things at once but think it better than posting a new question every few days.
Ste
Phil B.
The monthly slot rally on stages will continue. Not as part of the club championship.
I think the rally class in the club championship will be run on the Aberstone circuit, running a different SRGB class each round.
The rest is down to Phil F.
Cheers - Phil
Phil Field
Hi Steve,
In 70's F1 you can glue the tyres on to the original hubs or Slot it, NSR or Ninco F1 hubs
Gear ratio is 9/27, original or slot it.
The 6 classes will be run like 2011 alternate each fortnight.
4 rounds per class, best 3 to count.
Ninco class is ninco GT only, need to decide on motor choice?
Rally class will be on aberstone.
Ref your mazda, Boxer 2 open can is best. 11 or 12 pinion with 28 - 30 gear.
You will need a AW starter kit which includes pod, stopper & gear. they do standard or lowered pod!
Hope this helps.
Phil.
WRP World Champ 2015/2016
Right then Phil and Phil, so my NSR 917K is eligible for both Le Mans GT and Classic GT?
I hope so, I only need to get a Ninco GT and DTM to complete the list.
So if my Mrs ever says "I can't believe these cars only cost a tenner each" your going to have to back me up lads, ok?
Phil B.
Well I`ve just checked this years GT and it says -
Le mans GT.
Any GT car which has run at le mans. Classic or modern.(Not Moslers)
No mention of NSR`s unfortunately.
Unless Mr F wants to change it and allow NSR?
Ninco DTM`s you will get for a tenner
Cheers - Phil
Phil Field
Discussion Starter · #18 ·
Ninco GT is the same as the last couple of years Moslers, Ford GT, Lexus etc.
NSR classics are allowed in Le-mans GT ( Ive edited 2011 regs!) they were allowed in 2011.
The best DTM Merc is the CLK one, not the earlier C Klasse.
Hope this clears a few things up.
I will post all the dates for next year this week.
Phil.
Phil B.
These classes -
Le-mans GT
Same as 2011
Ninco GT
Classic GT
What motors are allowed and what motors are banned?
Cheers - Phil
1 - 20 of 22 Posts
