Here the rules so far, more to follow...
Initially, we will be running 5 different classes of cars as detailed below. There are some rules that are common to all classes. No magnets allowed in the cars, no neo-mag motors or MB SlotDoDo motors and no silicone or polyurethane or Ortmann tyres. Wheels and tyres must not be visible outside of the wheel arches/bodywork when viewed from above.
Open GT Rules
Manufacturers
Any manufacturer, NSR, Slot.it, Thunderslot, Avant Slot, etc.
Axles, Wheels and Gears
Any manufacturer, but no F1 hubs allowed. Axle stoppers and spacers are allowed and may be plastic or metal. Maximum track width of 64mm.
Motors
Any manufacturer with the exceptions stated above. Motors may be taped or glued in place. Mortors may be mounted in angle-winder, side-winder or inline configuration.
Tyres
Any rubber compound with the exceptions stated above. Front tyres must touch the track when the car is placed in the slot. Tyres may be trued and glued.
Chassis
Chassis must match the bodies although 3D printed chassis are allowed if they match the body. Chassis may be strengthened or stiffened but no excessive trimming allowed. Body rock is allowed and weight may be added but must be inside the chassis/body and should not be visible. Suspension is allowed.
Body
Interiors must be fitted but may be standard or lightweight. Wing mirrors and windscreen wipers and aerials may be removed but rear wings must be securely attached and fitted at the start of each race. Bodies must be painted.
Guides & Spacers
Any guide allowed, any braid allowed. Spacers are also allowed on guides.
LMP Rules
Manufacturers
Arrowslot, Avant Slot, Fly, Ninco, NSR, Racer, Scaleauto, Scalextric, SCX, Slot.it, Sloter, Slotting Plus and Spirit
Any from the above list of manufacturers including PRS and PCS. No F1 hubs allowed. Axle stoppers and spacers are allowed and may be plastic or metal.
Motors
Boxer type motor from any of the above manufacturer with the exceptions previously mentioned. Motors may be taped or glued in place. Motors must be inline configuration only.
Tyres
Only unglued (PRS or Slot.it F22)tyres are allowed. Front tyres must touch the track when the car is placed in the slot.
Chassis
Chassis must match the bodies although 3D-printed chassis are allowed if they match the body. Chassis may be strengthened or stiffened but no excessive trimming allowed. Body rock is allowed and weight may be added but must be inside the chassis/body and should not be visible. Suspension is allowed.
Body
Guides & Spacers
Classic GT Rules
Manufacturers
NSR, Slot.it or Thunderslot
Motors
Motors must be standard as they come fitted to the cars. Short car "S" type motors only. NSR 20k Shark motors, Slot.it V3 21k or stock Thunderslot 21k motors only. Motors are not interchangeable between manufacturers and must be side-winder only.
Tyres
NSR 20x10x16 classic or slick, Slot.it stock size appropriate to the car and Thunderslot classic or slick allowed. Tyres may be trued and glued. Front tyres must touch the track when the car is placed in the slot. Tyres may be trued and glued.
Chassis
Must be standard and match the body.
Motor Mount
NSR red or black motor mount, Slot.it black or dark grey mount and stock Thunderslot mounts only will be allowed. No modified mounts allowed.
Body
Must be standard.
Must be standard, maximum width of track is 61 mm. Any sidewinder gear is allowed but motor pinion must remain as standard 11 teeth.
Guides & Spacers
Open GT Rules
Manufacturers
Motors
Tyres
Chassis
Body
Guides & Spacers
LMP Rules
Manufacturers
Motors
Tyres
Chassis
Body
Guides & Spacers
Classic GT Rules
Manufacturers
Motors
Tyres
Chassis
Motor Mount
Body
Must be standard.
Guides & Spacers
