1 - 20 of 23 Posts
· Greg Gaub
There was some confusion with my club recently and I wanted to make sure we had the correct information.
It is my understanding that the SCP01d3v3 will NOT WORK properly with the original SSD 6 car base, C7030, or the 4 car base.
Someone read something somewhere that lead them to believe that it might work on all the bases as well as the new 6 car base, C7042.
If that is the case, then there will be much rejoicing. I expect, rather, that there is to be some disappointing. ;-)
Assuming the answer is still "no" and that the 3v3 cartridge is C7042 ONLY, the next question is, will Slot.it be able to develop a single digital cartridge that can be switched between two modes of use, one each compatible with each type of SSD power base?
We're getting a bit fed up with the widely varying Scalextric OEM throttles, and would like to use better throttles, but we have a mix of power base types and can't all afford two cartridges each.
I know exactly how you feel Greg. I upgraded to C7042 from PB Pro, and I still have to buy my 3v3 cartridge. Just the cartridge costs me 2,5 scalextric controllers. However, having experienced the SCP on PB Pro, I know I want to upgrade to 3v3, I just wish there was a simpler (cheaper) solution. I once read somethig about the wireless controllers from SCS and that they were busy with investigating possibilities to connect SCP-01? I can understand that If you put something between powerbase and controller (the receiver) It might be possible to keep the original cartridge. It will still cost money, but with the benefits of wireless. Probably understood It wrong though...
I am pretty certain that 3.3v will only work with the C7042 Powerbase. It is just simply that it generates a voltage range that simulates the voltage that a resistive scalextric controller would generate. The fundemental problem being that the resistor in the top of the potential divider goes to 3.3V in a C7042 & 5V in C7030 & the 4 Car Powerbase.
Of course Slot.it could design a switchable cartrige & in all honesty I do not know why instead of designing a 3.3V cartridge they did not make that switchable? Will they do one, somehow I doubt it? Best thing is to PM Maurizio.
Again SCS could solve the problem, and make provision for all combinations, but would have to do switchable versions of both the throttle box & the box that plugs to the Powerbase. So quite a lot of work, and some added cost.
Rich
· Vendor
Making the current unit switchable would have required a significant rework of all existing cartridges - even those sold to SCX, Carrera, Ninco owners.
In the future, digital cartridges will be switchable, but I cannot really give any dates, and off my head certainly not in 2012.
Unfortunately we tried solving the issue with a couple of resistors, as external add on, but a combination of some specs on our HW and Scalextric SW prevented it from happening.
Maurizio
· Greg Gaub
Thanks for the response, Maurizio. It's not unexpected.
Can you clarify for me why non-Scalextric cartridges would also need to change?
My suggestion would be to keep the original cartridge as you already have for "all digital" (old scalextric), but change the 3v3 controller to be switchable for the two types of Scalextric. You still have only two digital cartridges on the market, but one of them can do both Scalextric old and new. I doubt very much that SCX users are specifically ordering the 3v3 controller anyway, as they can still buy and use the original digital controller.
I will need to buy a new cartridge sooner or later anyway, as I have only the original digital controller. It would be nice to only need one cartridge that only needs a dip switch flip to use on a different SSD base, rather than two cartridges to keep in my slot box.
On the bright side, it should be possible for Andy to do the same for oXigen wireless controllers as he has done for Scorpius Wireless, and integrate them through SSDC for Scalextric car control.
· Vendor
We do not have 'non Scalextric' cartridges, as the cartridge is (or was before 3V3) universal. A 'switchable for SSD from 3.3V to 5V' cartridge would require a change which would be quite larger than the change necessary to make a 'single use' 3V3 unit, and that change would have been necessary on all cartridges - a possibility would have been to fork a 'Scalextric only' version which would do both... but this option didn't even came to mind honestly.
That's the history of why we haven't made the change on the 'universal' unit but 'forked' a 3V3 one.
SSDC:
I guess so, we'll be happy to send protocol details but we haven't received any requests from SSDC developers.
Maurizio, out of interest, particularily as wireless is now becoming quite prolific. We have SCS, Throttle-Pro, Scorpius. Carrera have anounced Wireless throttles for Digital & Ninco for Analog. Then of course oXigen. As far as I know all are using not only different base chips but also different protocols in the 2.4Ghz band.
Just wondered which system oXigen uses? Is it Bluetooth or a different base chip? Is so which chip have you chosen?
Rich
· Greg Gaub
QUOTE (Slot.it @ 22 Feb 2012, 05:55) <{POST_SNAPBACK}>a possibility would have been to fork a 'Scalextric only' version which would do both... but this option didn't even came to mind honestly.
That's the unfortunate bit. As our club has a mix of old and new SSD bases, we can't all afford both cartridges. It would have been oh-SO much better if the new cartridge were a "scalextric digital only" cartridge that is switchable between 3.3 and 5v. Alas, hindsight is 20/20.
· Vendor
QUOTE (RichG @ 22 Feb 2012, 15:13) <{POST_SNAPBACK}>Maurizio, out of interest, particularily as wireless is now becoming quite prolific. We have SCS, Throttle-Pro, Scorpius. Carrera have anounced Wireless throttles for Digital & Ninco for Analog. Then of course oXigen. As far as I know all are using not only different base chips but also different protocols in the 2.4Ghz band.
Rich
Hi Rich.
It's based on Nordic 2.4GHz chips. Application protocol is entirely ours, no ZigBee or such.
Maurizio
Thanks Maurizio, I thought they looked like the nRF24L01+ chips but difficult to tell from the pictures. Looking at the picture of the wireless cartridge it looks like you have added a PA / preamp to the input of the chip, is this the case, and if so does the dongle have this as well?
Anyway I like the choice of chip, and it means that at least oXigen & Scorpius are using the same chip albeit with different protocols. So this opens up some options for the future.
How soon will these be in the shops, I am keen to have a play?
Rich
Hi Zipp,
DIGITAL, SLOTIT, AND GE115B are the only markings on my 3v3 C7042 cartridge - don't know if that's exclusive to that cartridge though and whether there are variations.
Hopefully Mr Slot it will confirm?
Chris
· Greg Gaub
Discussion Starter · #16 ·
It won't be BAD, but it won't work correctly. The brake and lane change buttons will not work as they should, and the combination of throttle and buttons will also have unintended results.
This is why it was originally thought to work fine, because it does something. It's just that the results aren't appropriate all the time. ;-) Give it a go, just for a laugh. It won't hurt.
But yes, unless you know you have the 3v3 cartridge, you don't. I recall you got yours quite a while ago, long before the APB and 3v3 controller came out.
Just for information the SCS wireless system will make a bridge between any type of Controller 5V, 3,3V or resistive to any type of base APB, PB6 or PB4.
The different modes are set with a jumper in each Transmitter.
Please read our manual for more information, you find it on our WEB paage, www.slotcarsolutions.com
Best Regards¨
Thobias
SlotCarSolutions
· Greg Gaub
Discussion Starter · #19 ·
Thobias,
Are the v4 wireless kits shipping? A friend of mine ordered 3 sets a while ago and was told that production hadn't begun, or that there was a delay of some kind (I forgot). Do you have all the parts you need ready to go for current orders?
1 - 20 of 23 Posts
