1 - 2 of 2 Posts
I have a Trakmate power supply.
Right now, I'm successfully running a 2 lane Carrera track, wireless.
I'd like to run a Carrera 4 lane, wireless.
So I'm assuming I need another cable like the one that came with the Trakmate, and just double up on the positive / negative terminals, two black cables coming from the neg, and two reds coming from the pos.
Trakmate wants $55 for another cable. This seems expensive to me.
Wondering if I have any other options out there as far as cables go...
I searched online a bit but couldn't find anything.
Any suggestions?
Rich Dumas
I must be missing something here. I can't find a power cable on the Trackmate site. If you were using Trackmate to count laps you would need to change the sensor cable to one made for more lanes, but that has nothing to do with the power connections to the lanes. If the sensor cable is what you actually need you could save money by making your own, you just need to know which pins to use and be good at soldering tiny wires to little pins that you can hardly see. If you have a track power relay that is connected to a Trakmate interface that will work OK as is.
1 - 2 of 2 Posts
