Yep, and the only Grand Sport roadster that I know of! Was a good match with the chassis too - I tested for the first time at Bordo the day before the race, and quickly lowered the gear ratio (numerically) and added that chunk of lead! I had plans to put on a brass pan once I had more time, but never got around to it...
That was a very typical Midwest club construction for the MkIV - heavy and low down, because it seems they ran on slick, high-adhesion tracks with lots of moo. And did you notice that it's a "proto-anglewinder"? In fact, it's a real sidewinder, with integral wheel gear unit to narrow the track, but on this one (and a few others I found), the builder still had to cock the motor over a couple of degrees to fit it in... maybe that eventually led to Roy Moody coming up with the first real anglewinder?
Steve, PYL is Pierre-Yves, our guru here for the artistic side of things, and much else! He also painted the Corvette (but I did the pipes!), restored my Policar P3 body, etc. He did a small range of resin cars, all beautifully done, along with various vac bodies like the one you have - and also carved the masters for part of the PSK range. A very talented guy, to say the least...
