1 - 12 of 12 Posts
Well I was running my lister the other day and after the motor popped ot once and the drive shaft popped out twice I decided it was time to make a chassis. Here's a shot of what I've done so far.
I'll keep posting some pics as I go along.
If anyone's interested in chassis for the lister let me know.
Derek
Allan Wakefield
I am interested in a chassis Derek, especially in the 'as you go' photo series, I wondered how this was done ! thanks for taking the time to do it.
Well it's almost done. All I have left is to model the grill mounts on the front section and open up the guide slot to accept larger guides (thanks Al).
The rear section was a real pain and I'm not too sure how well thats going to machine. I wanted to keep the price down on these and every time you add curvy stuff the machining time goes up.
There seems to be enough room in front of the motor for a straight axle if you want to run one.
Thanks for looking
Derek
Allan Wakefield
Can you design in some vertical flexibility to the solid front axle?
Solid front axle is far more desirable btw.
I could cut the front frame rails loose on the front and each side from the chassis pan. This would allow the forward frame rail and axle flex up and down like a torsion spring.
It would probably bend over time though. 6061 t6 aluminum has a pretty good tensile strength to it so it might work.
Derek
QUOTE (Swissracer @ 23 Oct 2004, 14:25)
<{POST_SNAPBACK}>
Hi Thanks for the interest.
there was avery interesting discussion about chassis flex here. Metalica viper
It uses 3/16" od flange bearings for the rear axle and a 5mm od bearing for the drive shaft.
I'll post a notice when they're available.
Derek
QUOTE (fola @ 24 Oct 2004, 08:28)Hi Derek,
thats an impressive project.
Do you not feel that the chassis will be too rigid?
And what bushings/bearings will the rear axle take?
How ever it comes out, I am very interested in buying
Keep up the great work .
f
<{POST_SNAPBACK}>
1 - 12 of 12 Posts
