I needed a sidewinder chassis for one of my projectsand decided to try some of the ideas that Chris Briggs has put forth on his web site:
Chris' site
-and I wanted to try out a new mnin-torch that I bought that uses MAPP gas for a hotter flame than propane:
The front and mid-rear sections of the chassis were cut as one from 0.062" brass and then separated after the slots for the pivot and torsion springs were cut. The front axle carriers are also 0.062" brass and were brazed (with my new torch) into extensions of the torsion spring slots. I did this so that there would be no chance of subsequent soldering steps loosening them. The guide carrier is 0.062" steel (I don't like it when things break!) and the cross brace is another piece of 0.062" brass, both of these parts attached with Sta Brite solder.
More details and the rear section when I find the memory stick from my digicam!
EM
and, no "Hybrid" does not mean that there will be a miniscule I.C. engine to supplement the electric motor.
Chris' site
EM
