1 - 9 of 9 Posts
Hi All. Could someone please explain this.
Controller A Club Parma Economy Hand Controllers 15OHMS
Controller B My Parma Plus 15Ohms
Tested all 5 controllers, all test at 15Ohms +/-1Ohm
Ciub Controllers way quicker than Mine.
Mine way better breaking.
All 6 wired the same way
Why?
I would have thought that Parma Plus would be the quicker than Economyl, but they all should be the same as they are all 15Ohms.
Andy
A weird one indeed.I am not to sure of the electrical difference's between the Plus and Economy versions.
I can only summise that the varaition of resistance between off and full throttle differs between the two.The one varies exponentially and the other in a more linear fashion,but both should provide the same maximum voltage at full throttle to the car from the same power supply.
As far as the braking goes perhaps the Plus version does not provide a full short circuit accross the motor but a deliberate partial one so that the car does not deccelerate as quickly
Be very interested to know the reason,it must be logical, but sometimes strange coincidences lead you up the wrong path.
Please let us know
Bryan
· Rich Dumas
The best way to compare the controllers is to measure the voltage across the track rails with a motor running. An open circuit voltage measurement will not tell you much. My own controller has a relay that bypasses everything, including most of the wires when the controller is in the full speed position.
QUOTE (RichD @ 10 Jul 2012, 15:36) <{POST_SNAPBACK}>The best way to compare the controllers is to measure the voltage across the track rails with a motor running. An open circuit voltage measurement will not tell you much. My own controller has a relay that bypasses everything, including most of the wires when the controller is in the full speed position.
OK, I'll try that.
After playing about I can see that the clean was well worth it. No difference I could see on FULL but under breaking a big difference. The car stops, rather than creeps to a stand still.
I have ben used to running without breaks, but as the rest all have breaking, I would be at a loss if I did not have it. You get deeper into a corner.
Still, Race night tomorrow, we will see how it coes better then.
1 - 9 of 9 Posts
