Here is a quick guide of how I chipped one of my Start LeMans cars
Here is you START Car
Take it apart
I use a chip from a donor Porsche Boxster Car
By using this method it is just a case of swapping out the components
So start by removing everthing from the START car
Replace the motor first
In the START Car there is a nice hole for the LED
Carefully adjust the LED so it fits into the hole and note where the CHIP would sit
Next Cut Off the little points
Then CUT Out the the area where the CHIP would sit ( Be careful you lot as you need to use a knife for this part )
Plug in the GLUE Gun to warmup ( I go this one in poundland
Put some GLUE in the area where the chip will sit
Stick the chip in the gap you cut out ontop of the glue
One thing you need to do is adjust the BRAIDS The FIRST photo shows how they normaly come and The SECOND How you change it too
One other thing you need to do is remove the wheel and put the wires under the axel
Replace the wheel and this is what it should look like
Hot Glue the MOTOR in and ADD some weight in the FRONT
Put it back together
And underneath all is neat and tidy
Should take you about 15 mins
Have Fun
Michael
Take it apart
Michael
