I modified my Carrera pit lane entry to include the fuel sensor from the pit lane adapter. I did this for two reasons - one, because I use Smartrace for my RMS which requires the fuel sensor track for refueling and two, because I am conserving space on my layout.
It was very straightforward, since the fuel sensor chip simply taps into the power from the track. You just need to remove the back cover on the track to take it out. It is simply pressure fit with no screws.
The pit lane entry track has enough space to fit the chip and sensor.
I decided to locate the hole for the sensor as close to the end of the track as possible...more on this position later. The hole is made with a 7/64 drill bit.
Chip fits well and I secured it with hot glue.
I placed the sensor 5mm from the rail, which is the standard placement of sensors on straight track. After running some test laps, I realized I had neglected to take into account that the car would still be traveling at an angle at this point, so I needed to adjust the sensor location after initial tests.
What's a second hole among friends? The new hole is 10mm from the rail and worked perfectly when the cars were at speed entering pit lane.
I kept in mind that I plan to change my layout in the future, so I sealed it up with electrical tape to keep it clean. The modification is not permanent and can easily be swapped back into the fuel adapter track later.
You can see the sensor on the left by the #4 car's front end.
Refueling in Smartrace in action! Last night, I ran a few test laps to make sure it worked. Success! Today I ran about 150 laps, refueling 6 times with no failures.
