I've done a rough sketch of a 'torsion-bar' chassis I'm thinking of building and would appreciate any comments and advice regarding its design...
Its for a car I'm currently building that will have long wheel base (100mm) and a relatively heavy resin cast body.
The idea is to try a keep the car more stable in and out of the corners. I will attempt to contruct it either from plastic or resin cast (useless at soldering
) with the pivot bar either inserted directly into a thick chassis floor or supported on pillow blocks. Due to the nature of the body I know it will never be a super fast car but I would like it to handle well and promote a slide rather than a roll. Would this type be the right way to go
Thanks,
Marlon.
Thanks,
Marlon.
