I've just finished the 2nd car in Mac Pinch's range of resin shells depicting cars from the 30's through to the 50's.
This particular car is the Alfa 8 Cylinder
This car is fairly straightforward to build as it has a lot more room to accommodate Mabuchi or similar motors.
As I want to make all my cars in this series fairly even paced, I chose to use the wonderful little Scalextric MOTOGP motor.
Chassis is Brass rod and plate with the front tube axle mounted as a separate item.
Gears are Scalextric pinion mated to a Slot.it crown. Guide is TSRF
Wheels are Ninco Classics and tyres on the front with Patto's on the rear with cut down Ninco classics as inserts.
Alan
Alan
