I tried to run my APB 7042 in analogue mode (simply switched in ssdc - nice one Andy) but it won't work.
I suspect from what I've read previously that you cannot have the rails of the two lanes connected to each other. Is that the case? Can I do anything about it?
My track is a permanent 70' set up with a section of single track, so I cannot separate the two lanes. If this were using a true analogue Powerbase it would simply power the whole thing as one lane, and the second lane would be effectively dormant if no power was applied to it (I believe). I suspect the problem might be that the Powerbase is getting faux DC fed back to the unused lane and it doesn't like it.
When I pull the trigger the lights start to flash, which in crease as I pull it more, then it goes into safe mode.
I would like to be able to use analogue if possible but I don't want to pull up my track to do it.
Any ideas appreciated. And for Andy- assuming m understanding is correct, is this something that can be 'fixed' by firmware means?
Andrew
Andrew
