Hi all,
all over the year the birchtrees arround our house give away somthing: pollen in spring, exuding resin and semen in summer and in the end thousands of leaves in authum. Untill now I used the semen to imitate 1/32 leaves but now found that pollen can be greatly used for bales of straw in 1/32 scale:
If pressed a little they fall apart. Seperating the brown core from the yellow semen you can reach any color (more yellow or brownish) you want.
little wood of about 1 x 1.2 x 3cm, glue, the pollen and little copperwire will give a scale standard german bale of straw (100 x 50 x 40cm in 1:1)
Caution: This scenery-item might be problematic for allergy-sufferers
Regards Jens
