1 - 9 of 9 Posts
Just finished the first step in creating my first rubbermould , creating a "buck" using Bondo body filler poured into a vac formed body .
The resulting casts look quite promising , a few pin holes to fill and some fine detail to add ( door lines and scoop areas to deepen ) .
I have seen several articles about resin moulding but none of them show how to create "seal offs" in the mould for the glass areas .
Does anyone have any ideas or links ?
The body filler works very well at a fraction of the cost of hobby resin , and is very workable after setting . Unfortunately I don't have a digital camera so I wont be able to do an illustrated step by step . The two cars I am working with are the Chap 2F and Mclaren M8a aquired from E.Pay with Riko chassis,s .
Richard
By sounds of it I think you'll need to do a two part mould to get the best results. Here's a great 'how to' article on two part moulding Mark Gussin
And here's another Alumilite
I'll be posting how I did my two part Bentley mould soon.
Alternativley if you're slush casting the body filler you can create a 'dam' effect by building up the inside of the vacform in the window areas, this will prevent any body filler flowing into theses areas when slushing.
Regards,
MAF
Hi Richard,
Its going to be the 1938 Bentley Embiricos as raced at Lemans in 1949-51.
Still crafting all the detail bits on the slush cast (below) at the moment before I do a two part mould. Here's the latest pic...
Best regards.
Marlon.
Hi Marlon
Very impresive a little more advanced than my slab sided GT,s : )
Did you carve the master or was it a copied from an original body ?
Perusing the local art store yesterday I noticed they had clear casting resin , is this strong enough for a slot body ?
Richard
Richard,
I scratchbuilt the master...
Here's the mould...
I used a synthetic clay than can be fired in a domestic oven to construct the master. There is a post on this forum 'Bentley part 1', but I broke the links to the pictures somehow. There's a link to the supplier and type of resin I used on that post.
With regards to the clear resin, it depends on the type. Polyester resin is more brittle than polyurethane resin which I use and clear is available in both types. I haven't used polyester resin so can't be sure how brittle it is or how it would stand up to my driving (regular shunts
Marlon.
1 - 9 of 9 Posts
