1 - 7 of 7 Posts
Tony
Can anyone help with a source for plastic body mounting posts. Used my supply that I have had for years and can't find where to buy them from.
Thanks in advance.
Hey BT,
As I have said so many times in the past, which you probably will not have seen !!.
Get a length of ally tube 3.25 id and 4mm od, from your model suppliers.
Get some insulation off mains wiring.
Remember to turn off the leck trickery first, and twist the insull into the tube.
Voila, as the French say, there one has it !!.
Any length body posts.
Insert a 2mm (slotit) allen screw into the top end, then attach post to chassis.
Adjust the allen screw to give required body clearance.
Invert body, and then, Araldite posts to body, still attached to chassis.
Easy Peasy.
vbr Chris A.
1 - 7 of 7 Posts
