1 - 9 of 9 Posts
Hi Chaps,
I notice a power loss to the cars when changing from Digital to Analogue mode on the C 7042 powerbase.
I am using the same controller and the same car (a Digital chipped Porshe) I know that the brakes are different, but the car is significantly slower on the straights, or even when you just rev it up. I have checked the power scale and it is on 100%.
I can do a lap in Analogue in just over 3 secs, and then only change the powerbase to Digital, and I can get 2.7 secs, significantly faster !
Is this usual, or am I missing something?
Thanks for any input.
Cheers Martin
· Digital Guru
hi
you can notice this difference if you place a chipped car on a normal analouge track,i think it is down to a slightly lower voltage to the motor as the chip uses some of the available power.???
· Administrator
I think power loss is the wrong term, the system although it uses the same components the way they operate is different, PWM power instead of rectified AC. I would go with BigBird though, try the same car with the DPR plug changed for a blank. I'll bet you get closer to 2.7 seconds. But regardless the power in analogue mode will be what you get. If you want faster do the variable voltage mod.
I just took out the Digital Chip to see if that is the bit draining power, and guess what........... it was !! Full power to the car, and a faster than 2.7 secs lap, due to the less sudden braking.
Thanks for the help, I was a bit puzzled, it s is a shame that it does that, my kids like to swap between cars almost per lap. Still, never mind the system is great anyway.
Cheers for the help.
Martin
· Administrator
Good, that clears that up then. Personally I use analogue mode for analogue cars, if I'm going to run a digital car I always switch to digital so that I get my brakes back.
RikoRocket,
Maybe add a link to the APB Variable voltage mod to your signature so it is easier to find.
Cheers!
1 - 9 of 9 Posts
