While waiting for mosfets to arrive for my C7005 chip repair I have begun rebuilding some GT3R Porches only to discover that two of the C7006s inspected so far have HRN/ST 05(?)20 and HRN/ST 1014 microcontrollers - on somewhat differently populated boards.
These cars have rather dim, grotty little smd light bulbs wired to the motor. Hence my plan is to flash the chips with INCARPRO and add upgraded lights, including the brake light feature, wired directly from the chips.
This should be easier than on the C7005 chip as programming pads are present on the C7006 boards.
However... I cannot find a spec. for the HRN/ST microcontrollers on Google, and so am unable to check the programmer connections pins and required voltage.
So please:
1) how do I identify and set these chips up in MPBLAB IPE in order to programme them with PICKit4?
Thank you!
So please:
Thank you!
