So attaching a 104M cap, taken from a broken SCX RX42 motor, to the rail makes all cars as smooth as butter & doesn't seem to interefere with digital.
A 103 cap is the same when the car is running on the track and you only notice the (reduced) low end pulsing (spiking rather) if you lift the car up.
So, in the short term, I've connected a 104M cap to a half straight via a powertap lead which I can remove easily and eventually I could solder it to the half straight & just put that in for analogue. Alternatively, I could just put 104 caps in all 21k+ rpm cars which is probably the most sensible.
Ebay has a few sites with cheap caps so I'll probably go for the 104 if there's no other downsides?
A couple of techie questions:
Does it matter what the letter is after 104 is (it's M in my SCX cars), and is the the volt no. important - I've seen 25,50 & 100?
Eg:
this one is marked as 100nF / 0.1uF - Ceramic Disc Capacitor (104) - 25V?
Also do they need to be these brown ceramic ones as I see many different colours & materials?
Chris
Edit: Just to clarify - this cap makes no difference to the max revs pulsing. It just seems to smooth over spiking in the low range power which is presumably from a faulty/out of tolerance component in my APB.
