1 - 5 of 5 Posts
Hi i am just starting to get addicted to the sport of slotcar racing i bought a parma flexi 2 and race for fun at a local hobby shop. What is the next step to getting more serious? Also what are some general tips and secrets of the trade?
welcome to the club of addicts!!!!!!!
I would inform myself on what race classes (type of cars) are driven at your local club. I would start with a rather easy class.
This way you get cars that you can compare with those of others and try and find (and develop) the secrets of setting up a slotcar according to your personal driving style.
So don´t hesitate and start asking!!! This is the only way of gathering information (in your club and here in the forum). You will learn from the mistakes of others, still make your own mistakes, but your cars will improve in its handling.
Go for it,
Nico
http://grenzlandslot.com
If your club has any inter-club championships then take part in those too. They're a great way to socialise with other slot jockeys and don't worry about not winning or even coming last - participation is the main thing (at least until you've done a few!
Mark.
And you can try blueprinting your flexi.
Take it all apart, really study how it goes together.
1)start with the rear bushings...when you put them in, is there any slop? Do the rules allow you to glue or solder them solid? Put a naked axle through the bushings. the axle ought to slide easily though one and into the other, if it does not, they are not straight. Once in position, glue or solder if allowed.
2)If allowed, check the alignment on the motor. Are the brushes exactly 180 degrees apart, are they wearing evenly? without the springs on, does the arm spin freely in the can? If any of these are not true, fix it!
3)mount the motor. Does it sit flat on the pan? Is the mesh smooth? If not, fix it. Then, if allowed, solder the motor in postition. If allowd make an "L" brace that attaches the can to the bushing on the side away from the gear to make your box rigid.
4)Assemble the rest of the car. Does the guide move freely but without a fore/aft rocking? Do the pans move just a little but without bind? When the car sits on the block, does it sit flat on the track? If not add a little weight behind the guide until it does.
5)When mounting the body, have you reinforced the stress points? When the body is on the car, does it touchanything that moves?
When all this is perfect and you are comfortable driving it...THEN think about a faster class.
Fate
1 - 5 of 5 Posts
