Until recently, I would always have supported the freedom to buy and use 'the best' controller 'you' can afford. All the bells and whistles 'you' like and the more adjustability the better.
But recently, I have been compelled to consider a different angle.
It was very sensibly put to me that, if a bunch of people with a variety of disposable incomes want to enjoy FAIR and enjoyable racing together, yet they still permit 'sky's the limit' expenditure on controllers, this has near as dammit the same ability to disrupt the group as allowing unlimited mods to the cars. Hmmm!
I have to admit the fellow made an excellent point.
There would be no problem with open racing (depending on the rules as always), but in a friendly group environment it could easily result in the group falling apart. Just to clarify - if 'you' can afford an all-singing all-dancing DiFalco, for example, should 'you' be allowed to use it in competition with a bunch of your buddies who can't? If you insist, you are going to pee them all of them off and you may end up witth no one to race! Conversely, if they insist, they are going to pee 'you' off - all that money and not be allowed to to use it? Come ON chaps, you have to be joking!
I haven't made my mind up, but it's worth some thoughtful consideration, I believe.
OK, I have to re-phrase this: I KNEW what company made these, I just forgot because it is not really important... First, controllers are boring, and second, controllers are even more boring.
Now, such controllers as Brian describes were very popular at the time when you could not buy a RTR car because no one made any except for the rather mediocre 1/32 scale plastic junk from UK or USA, and you had to make your own from either brass chassis kits or scratchbuild from the few bits and pieces available. We are talking 1959 to 1963 here. Several companies in fact made similar controllers, some of them had a bicycle handlebar plastic handle, some did not.
It is not ANY of the well-known companies, and definitely NOT Towerstat. It is an obscure name and I can't recall right now because after a certain age, the brain cells are becoming cottage cheese and I am right about there now.
So I tell you what, the next time I run across a pic or an ad for these, I'll post the results and everyone will be happy.
This was also the era of really WEIRD controllers, and I have a few boxes full of these things, from "electronic" to analog, from intensely funny to down ridiculous. Cox and MRC took care of everybody after 1964. Russkit put everyone to the same level by 1969. Scalextric has still not learned how to build a decent one by 2003, and Carrera still has its 1965 Atlas copy in every set they sold ever since.
At least now I have a REASON for not remembering the name. I'm not insane.... it just wasn't a name worth remembering!
QUOTE We are talking 1959 to 1963 here
Just HAD to give my age away, didn't you!
Here, I think they may have lasted longer, before RussKit-style controllers took over. Many R4 owners had the add-on external resistors with adjustable tap-points and other goodies and were reluctant to change.
Probably sticks in my mind so solidly because, for me, it was very early in what was to become ten years of single-minded slot racing! Thankfully, sponsored for most of it, because I can't imagine having to pay for everything - even back then!
from ninco to group 27,i use my omni-cidex.
we race cox to momo ,i still use my cidex.
so far it has been discontinued,i had one fabricated and it was even better and lighter than the original one.
Hmmm...let's see if this jogs your memory. Ram 4 ohm controller with a bicycle grip stretched over what looked to be something cheap like masonite. The trigger was a piece of brass plate with the end twisted to form a thumb press. There was a tiny return spring below the trigger and the resistor was angled and at the top end of the controller. It looked like something that you could fabricate in your basement. Sound familiar?
They were basic looking but had a smoooooooth trigger action which could be used by the thumb or inverted for index finger use. Our local track used them as rental controllers back in the '60's (that's 19 not 18) but they could be used with a single 24 wind or a dbl 27/28 in a pinch! Must have been dumped on the Canadian market...much like those unreliable rectangular holed Mura B-cans.
Bob, very, very close! But the handle was a metal tube - aluminum, I believe - slit and flattened on one end to mount over the board that had the trigger and resistor mounted. The trigger sounds like it. I recall the resistor mounting on the front edge rather than the top though. Some had bicycle grips, though they may have been added by the owners. The resistor was made by Ohmite - almost identical to the ones still being made by them! Aftermarket parts (possibly made locally) included a reworked resistor that had several isolated bands for connection to a large, high-power external resistor with adjustable clamp rings.
Now that I've talked the subject to death, and bored everyone to tears, I have promised myself to.... forget the R4.... forget the R4....
We are talking about the same controller. I forgot to mention the aluminum tubing and with regards to the resistor position...yep..it's on the front...my mistake.
Anyhow...I think we've lost everybody on this one.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
SlotForum
