I did some simple measurements of the analog voltages from a standard digital Carrera handset controller to the control unit using a driver's display and a car on the track with some interesting results. For the car on the track I used the motor pitch and current draw from the power supply as indicators of speed. Values are approximate as I didn't go to extremes for accurate measurements at this time. Plans are for a more thorough approach later.
1 - The maximum digital speed is reached well before the maximum possible voltage from the hand controller. ~4.5v (red) is supplied from the control unit to the resistor divider which resulting in a maximum analog voltage of ~2.25v. Maximum digital speed was achieved at ~1.45v (yellow)! Only about 2/3rds of the slider is used...
2 - The driver's display indicator remains the same for 2 speeds values from the hand controller.
3 - For the car I used, the motor started before and speed was indicated on the driver's display.
Speed Step | Hand Controller Voltage | Driver's Display |
1 | ~0.265 | none |
2 | ~0.365 | 1 - red |
3 | ~0.42 | 1 - red |
4 | ~0.51 | 2 - red |
5 | ~0.59 | 2 - red |
6 | ~0.68 | 3 - green |
7 | ~0.75 | 3 - green |
8 | ~0.84 | 4 - green |
9 | ~0.93 | 4 - green |
10 | ~0.98 | 5 - green |
11 | ~1.07 | 5 - green |
12 | ~1.14 | 6 - green |
13 | ~1.22 | 6 - green |
14 | ~1.3 | 7 - green |
15 | ~1.42 | 7 - green |
The measurements where done with a digital scope using statistical measurements reset for each step. There is a bit on noise on the supply voltage which effects the values especially at the lower voltage levels.
