QUOTE (Camber @ 24 May 2011, 09:34)
<{POST_SNAPBACK}>The inside corners at our local track are pretty tight, I'd say somewhere between outside R1 and inside R2. Our 1/24 plafits go around no problems, and those guides are big.
- Cam
QUOTE (MrFlippant @ 24 May 2011, 10:13)
<{POST_SNAPBACK}>Carrera guides are even longer than Plafit guides.
QUOTE (Scootcar50 @ 24 May 2011, 11:02)
<{POST_SNAPBACK}>Don't have anything to give accurate measurements of depth but what I can measure is the Carrera guide is 25mm long and the Scaly guide is 20mm long
Hope that helps.
Assuming Scootcar's measurements are correct, the 1/24 plafit guides are the same length as Carrera.
I had to cut about 5mm off the length of the guide on 2 Carrera cars I have to go around my Scaley track (tightest corner R2). However, most routed tracks have 1/8" (3.2mm slot width) as opposed to Scaley approx 2.5mm (I measured a track piece and it varied from 2.4 to 2.6mm slot width). This would have a significant effect on how tight you can have your corners, they dont have to be large and wide, in fact they can be very tight. Go with min 8mm deep and 3.2mm wide slot and I cant see any problems
To give an idea, I have no problems with this 1/24 Plafit going around my tightest corner.
- Cam
