Can you change the standard scalextric bearing for the brass ones?
A andy · Registered Joined May 7, 2004 · 67 Posts Discussion Starter · #1 · May 10, 2004 Only show this user Can you change the standard scalextric bearing for the brass ones?
M McLaren · Registered Joined Jan 4, 2004 · 2,472 Posts #2 · May 10, 2004 Only show this user Yes, namely Scalextric brass bearings. Contact Slot32 or Pendle. They should be able to send you some overnight. Hope this helps. Lotus
G Gaugemaster Controls · Registered Joined Jan 23, 2004 · 555 Posts #3 · May 10, 2004 Only show this user Why not change them for real roller-bearing sets from Cartrix? Contact your local stockist or see the Gaugemaster Website Aaron
