1 - 9 of 9 Posts
Hi guys
So just chip a gt40 and as am driving it around the track it keeps changing ID
without coming off or crashing or running over LC's.
It mite do a couple of laps then just stops along a straight
pick up anther controller and car has changed not always to same one.
Has done this now about 30 times
any answers guys ?
Ps is a C7006 solder chip.
regards ade
Digital Guru
hi Ade
do you have the orange capacitor fitted at the pick up feet and at the motor terminals?? And is the braid plate a nice snug fit on the guide flag.??
Also try running it with the rear wheels in the air and blip the throttle across the entire range and see if it changes id then..
Hi ade
only got the ferrite man on motor end it one of the old push in pickups.
which i solder on the side of the wire spades which is what i do to all the old cars ive chipped.
plus just done 2 gt40's this morning and the other one is ok .
will try lifting car and trying when I go back up to the loft later after lunch.
regards ade.
OK tried with car jacked up and nothing happen .
So back on track
Id to White done 7 laps then lost ID
it went to Yellow done 6 laps then lost ID
Orange done 5 lost ID
White again 6 lost ID
Green 8 Lost ID
Blue 9 Lost ID
Red 20 laps end of fuel
This is strange never had this before used all colours
White twice then stayed on red till out of fuel
what the f##k is the problem.
regards ade.
Digital Guru
hi
as it runs in the air no problem then it has to be interference on track.
So even though other cars have run without it it may be worth trying to add the capacitor to the pick up feet or claim the chip is faulty and ask for a refund..
You can send the car to me if you wish Ade and i will have a look at it for you.
Ade .... are you saying that you do not have any LCs in this circuit or that the ID is lost before the car reaches them?
What version of firmware are you using??
Hi Greg
Yes got LC's in layout but it seems to happen on along straight most of the time.
I even crashed the car and made it deslot a few times but didnt lose ID .
Im using newest firmware .
ade.
Try running the car with the "suspect" chip in a dark room. You will need to get down low and watch for small sparks from the braids contacting the track. You might get sparking occuring at track joints not just at LCs. If you see any sparks then it is likely that these will be causing disruption to the firmware in the chip.
Another thing to try is to subject your track a good dose of negative air pressure via a vacuum cleaner .......
1 - 9 of 9 Posts
