1 - 16 of 16 Posts
Last winter I bought at the Hy Foroslot A pair of balance, the normal and the crane, I began to spin the project and after months of
look forward to gather information and photos time and this is the result.
We begin by restating the chassis with all the mechanical
To measure the distances of the axes using the method of the clay, that gives me slack I want with the fender when put
the height of chassis / body
This is the first prototype chassis
It worked fine in my circuit, so I added traction.
Here with some decorative elements presented, besides cutting the soil to make it more real and added a rear window
I tried it when I realized that bordered on the inside curves and to modify the rear ramps
With a dolls house MiniArt I get inside
Tamiya gray primer, three coats of yellow metal effects and money spent
All the parts for ensambly
Each and all mounted, the metal effect is done by passing a soft lead pencil
Focos lajartijeros
That's all, if you have any questions or want clarification of the process, will try to answer
A greeting.
Gerald Lambourn
When I hired a Citroen Tube for a move I felt I had become half-French! Just a suggestion of the rivet counting type, the font(police) of the number plates needs attention, also the old type number plates don't have the "tirets", only the new ones.
I love the H Van and did one out of styrene a few years ago.
This one is great! Was there really such a vehicle as the 3 axle transporter version? It is so cool and your detailing is exceptional. The two figures are very real, especially the passenger turing for a look. Of course they should be smoking Gitanes but that is the small stuff.
I do think you should move the guide closer to the front axle as it will better simulate the tight turning radius H vans had.
Love the TA car too. Where did you get it? Is is slot car or a body that can be made into a slot car?
Really great work
Thank you all and I'll start with the answers, I understand.
Put the Guide near the axis gives less turning radius, but less skidding, my circuit has very tight turns where I need skid
But i proves the change.
Existed a model with two rear axles.
In Spain there is little tradition of brass chassis like you, the level seen here it costs us, but we will continue to improve, also the rods I get free at work.
The Traccion Avant is a model of the house Tamiya chassis Slot Classic.
A greeting.
Daniel
Im sorry for my english but I used the Google Translator
Gerald Lambourn
The H van is a front-wheel drive with a really low floor at the back, the registration plate in the photo is about 2005, and the "Amis du Type H" poster is quite new too. The type H (tube) is characteristic of the French markets that we all love, they often have amazingly long rearward extensions for use as travelling shops. Gerald
PS You can date French plates at plaque.free.fr
Alfie Noakes
Hi Priamorex, This is a fantastic piece of work. Thanks so much for sharing.
Richard
Mr. Olufsen
How did I manage to miss this one? good call to bump it. Absolutely brilliant, what a nice and unique transporter. Well done.
Love the H type, infact most things Citroen, I've owned 6 different varients.
When I get a round tuit, I'll get on of the kits on offer of the 4 wheel one. I'd love a real one to use as a camper van , makes a change from a VW.
Thanks for sharing the build process
Simon
Yes please!!!!!!
That is simply fantastic! Thank you for sharing that and how you built it!
1 - 16 of 16 Posts
