1 - 9 of 9 Posts
Hi all.
For my final year project at uni I am going to write some software for the 6CPB. At the moment I am having problems receiving any data from the COM port.
The connection to the COM port is successful. If I remove the USB it throws an error. The state of the problem is that I'm not receiving any bytes of data.
The only other thing I have noticed is that when I pull the trigger on the controller the car still works. I was under the impression that when the PB is connected to a PC, the cars depended on receiving input from the PC and if there was no input from the PC then the cars would not move?
Below is the protocol info I have set so I don't think this is the problem.
1 start bit (0)
8 data bits
1 stop bit (1)
No parity bit
Baudrate: 19,200bps
USB Serial Port (COM4)
Any ideas what could be wrong?
Thanks,
Simon.
Digital "Tea Boy"
Hi there,
Good luck with your final year. Programming is not my forté.
What I do want to warn you about, is if you're using the new 6 car APB, then, do NOT plug and unplug your USB cable in/out while you have power ON. Everything needs to be switched OFF BEFORE you plug or unplug - otherwise your final year project is going to cost you a lot of £££££. Here is the link about it.
Administrator
Go to Andy's website and download the firmware upgrader software, that is idiot proof so if you cant update your powerbase then you have a cable or driver problem
http://ssdc.jackaments.com
Administrator
...not intended to sound negative in any way... The software is robust so if it won't work that means there is a PC or cable issue.
its so easy for things to come out wrong isn't it?
Hi Simon
Have a careful read of the protocol document & remember, with your own software, the controllers will work as normal until you send the Powerbase a packet. If the packet you send is in the correct format the Powerbase will then reply with handset positions, car crossing data, button positions etc.
Rich
1 - 9 of 9 Posts
