1 - 10 of 10 Posts
René 'Vialli' Christensen
How many - or few - LC's are there in a conversion set?
I have seen a Danish add that asys only one LC in a conversion set - and that makes no sence to me at all. At least you must have two LCs in my opion.
And which LCs is in the conversion set?
Is it inside-out, outside-in, left, right . . . ?
I plan to buy the conversion set and some extra LCs, but want different LCs.
And is it possible to turn a LC around so that i.e. a inside-out/left could be a outsid-in/right?
Slotrace.dk
There is only one LC in the conversion and one crossover.
You cannot reverse the LC they are either inner to outer or outer to inner both availalbe in left hand or right hand turns.
There is a right hand outer to inner in the conversion set.
You get the following in the conversion set
1 x C2478DW PORSCHE BOXSTER - RED
1 x C2479DW PORSCHE BOXSTER - YELLOW
1 x C8203 RACING CURVE R2 90 DEG
1 x SPORT DIGITAL LANE CHANGE SENSOR TRACK
1 x SPORT DIGITAL LANE CHANGE RH OUT to IN
1 x C7004 DC TRANSFORMER
1 x HAND THROTTLE - RED TOP
1 x HAND THROTTLE - GREEN TOP
or you could go for the Full digital set and get the following
1 x LANE CHANGE TRACK Left Hand, OUT to IN
1 x LANE CHANGE TRACK Right Hand, OUT to IN
2 x LANE CHANGE SENSOR TRACK
6 x C8205 STANDARD STRAIGHT
8 x C8206 STANDARD CURVE 45 deg
5 x C8207 HALF STRAIGHT
1 x C8295 ELEVATED TRACK
1 x BORDER/KERB ASSY LEAD-IN - LH
1 x BORDER/KERB ASSY LEAD-IN - RH
4 x BORDER/KERB ASSY R2 CURVE
ACC PACK containing SHORT SUPPORTS, CLIPS and PILLARS
6 x STRAIGHT BARRIER
Hope this helps
ScalextricRacer
That's a great help.
Thanks!
But I just don't understand why the heck they only put one LC in the conversion set!
And one cross-over?
You don't mention that in full list of the conversion set.
Yes, but on eBay it is hard to get refund if it doesn't work!
'Specially if you by of a private person and not a shop!
I figure I need £270,00 for a conversion kit, two extra LCs and two extra cars with controllers. And I might get 10% refund if I buy in Denmark!
Scalextricracer - I'm not sure I can save any money buying at Pendle Slot - at whom I normally shop - and if I get problems, I would rather deal with a Danish shop tthan have to ship everything to England.
Kai - I'll contact you or Bering if I need more advice about it.
1 - 10 of 10 Posts
