Unusually temperate here after the deep freeze, the weather gods insisted on some retribution. Craptacular weather always drives me to the slot cave, to wait out the monsoon.
The "Forever" rail project got some whittlen' over the holidays. Some projects fly off the bench, others fight to the death. The chassis bottom stop for the rear was installed early on. The lateral stops were bonded in, so the final clearance on the rear hubs could be set, and the rear axle could be cut to fit. JAGS mag rear hub is a much needed improvement over the heavy looking AFX/AW Fat lipped Ansen.
With the back tightened up, I finally committed to completing the dummy chrome blob up front. To finish the blown big block, I needed some vertical clearance.
Bits from four different diecasts stacked up, eventually gave me the look I was after. The final fitments are right around the corner.
I pick stuff up, I put stuff down. Especially resins. Once in a while, I make notable progress. Jaybob sent me this last year, so it's way ahead of schedule LOL! This example is quite nice. Chasing and clean up was marginal; but it had a few fitment issues, that required some careful whittlen'. We're hunkered down fairly level, on a narrow 440 now, with front independent wheels. Besides the obvious trinkets like wheels and tires and fixing the shoe overbite; hands down, IMHO it's one of the better things you can do for your 440's. Still a bit wide, I'll bob the front carrier a few mm.
Color is an ancient Testors blue metallic that I only break out when I need something special. It has a very fine mettalic that's hard to come by now-a-days. I dole it out with the eyedropper.
The glass insert is a rough fit, so I'm gonna think on it a while. Meantime, I'll be eyeing some period appropriate Vincents for the next JAG order. I can always re-use the bushed Ansens on another build.
The body work for this junk box "fatty pick up" project happened pretty fast. Then reality sets in, and I have to build a chassis under and around it. Once in a while I include something new if it isnt too risky. My experimental blind mount for Vincent independent front wheels is included. Obviously the hub portion gets shortened.
Here's the blind part. I works well on the bench ... yuk yuk yuk. Spins like a HW Redline wheel. The upshot is that if it fails down the road, I can simply pierce the outer hub and pin it conventionally.
There's a few tricky bits here. At first a straight axle was used, then an independent right off the frame horns; but I really couldnt get enthused about either, the former was ugly and the latter was weak. I settled on the drop beam for it's characteristic look, as well as re- enforcing the front. The frame horns were bent out, the beam was stuffed in, and the horns were bent back. Once I re-squared all four corners, the beam and front crash bar were soldered in.
For now, a fixed braid carrier will do the pick up work. I'll get it laced up and tested this week. I can always go with some sort of drop plate, if the handling feels off.
