1 - 5 of 5 Posts
Hiall, First off happy new year to you all,,
Now- ive cut my printer cable(useing ur3.0) to my track ,during a workshop clean up,
my question is ?can i just push the wires (not including plug housing),just wires say? pin #25 and# 10 or# 11 into back of computer??? without blowing up.
help needed, as im not really elect savy
neil(nam1961).
Sorry ,
the plug got cut off, so can i use just the push wires straight into the back of the computer,without having to get a new cable ,
from the sensors to comp ???
neil
ie track-------------cut-------comp
· Simon Platten
If you are asking can you push the wires into the Parallel 25 pin female socket without a plug, then the answer is Yes, providing you know which wire was connected to which pin. Just be careful that you don't create a problem by not having a good connection.
Thank you very much SY ,thats exactly what i was after,
i might try and solder pins to wires prior to putting into parallel port,
thanks again
neil
p.s might try and scroung new cable from old comps at work.
1 - 5 of 5 Posts
