Debug Level
789 Views 2 Replies 2 Participants Last post by  RAWeigel
Hi Dave,
We used the RC on the track at our club (Rio de Janeiro - Brazil).
Sometimes, during a race, the RC does not turn on the master relay.
This weekend I will do a test and if the problem happens, I would like to send you the LOG file.
What is the best option to enable debug level in RC?
<debug, debug low, debug medium, debug high, info, warning, error or fatal>
And # Debug Cache Level?
1 - 3 of 3 Posts
Just set the debug level to debug. That's good enough but you have to exit the race for it to write the log. What interface are you using? If its a parallel port that'll probably be your problem. I'll also likely have to walk you through what i need you to do to troubleshoot it but I 100% expect to see RC trying to deal with power correctly. It could be broken, but its really unlikely. Oh, and make sure you're using the latest release. If it is a bug you're going to have to update and I can't easily match logs to code unless you're running the latest.
Thanks Dave,
I use the latest version of RC (1.14.0.0) with Arduino + LEDs NEOPIXEL.
/Richard
1 - 3 of 3 Posts
