1 - 14 of 14 Posts
Hi.
I was cleaning out my parts box today and I found this.
I have absolutely no idea how I came to have it or what it is out of, or even if it is slot car related. It has a brass pinion and it runs.
Any help identifying it would be greatly appreciated
Steve
· Jim Moyes
From the connections at the end of the wires I would say it once got it's power via an MRRC guide, but I don't think the motor is MRRC.
Mr.M
It is an Airfix/MRRC motor from the Clubman Kit Series in the mid/ late 1960's.
This was the fast motor that was used. The ready built budget cars used a Johnson 111 motor.
The slimline clubman motor shown was a 3 pole, but there is also a 5 pole version which was used in some of the Airfix model trains.
The clubman motor together with the slimline chassis is very usefull for scratch building earlt & mid sixties Grand Prix cars. I have used them in Super Shells Ferrari 158 and Stackpipe BRM. It is a smooth motor and is ideal for home circuit use. A 35-40 ohm controller suits it best.
Geoff
Thanks guys. I really appreciate your help.
I did think scratch built 60's F1 when I saw it
but I'm so time poor these days.........but now I know what it is I'll pop it in the spare motors drawer 'cause you never know when it'll come in handy.
Steve
What sort of information?
Derived from the older Ks motor. I have seen it in their Honda, Eagle, BRM P261 kits as well as some sports cars. At a guess, perhaps the same power level as a current Mabuchi FC130s in a stock scalex.
They were not generally available in the U.S. When I saw my first, I was in love. Nice club track motor! Since then, I have cheerfully purchased every one I could.
Fate
· Jim Moyes
I thought this was a Clubman motor
Seems to be 6-pole, but there are only 3 comm plates.
Sure does scream, though!
Mr.M
That's the MRRC "split 6" or "star wound" motor that was fitted to some of there RTR cars , it's the same motor as the one found in the MRRC 4WD cars but with the armature shaft at only one end and a different plastic moulding for the steering unit, it's also an animal to use as it has far too much power for the kind of cars it was intended for.
[oneofwos]
· Peter Farrell
John
I must disagree I have used these motors for years and have never found them to be 'too powerful'. I might add that they have been mainly used with Classic Fiberglass bodies with brass rod chassis. They work beautifully.
Alfetta
I agree, the second motor (Mr Material's pics) is derived from the MRRC 4WD motor which pre-dates the Airfix take-over (Yes I was around in those days).
Check the motor bearings as they should be ball bearings.
The motor was very sturdy and was used in the short lived MRRC 1/24 ready built cars with vac-formed bodies. They went out of favour when the high powered Mabuchi motors came along, but still managed to win a major 24 hour race (I think it was in Australia) well after its sell-by date.
They were expensive motors at the time, and I could never afford one on my pocket money.
Geoff
Alfetta
Yes, if you put one into a brass rod chassis with a heavy body then the extra balast would probably tame it and make it quite driverble but they were originally designed to to be used with a light 1/32 injected body [i am sure that one of the RTR's was the 1/32 Eagle F1], steering unit and tall gripless rubber tyre's! all the one's i tried which include the 4WD versions have been a bit of a hand full.
[oneofwos]
· Peter Farrell
I still have my Mercedes 4WD it isn't a handful in fact it's easy to control. Mind you I have had a couple of days in which to get the feel of it. Sticking a couple of Neodimium Magnets onto the motor does improve the braking characteristics. Seems to improve the torque also.
Alfetta
1 - 14 of 14 Posts
