1 - 5 of 5 Posts
Can sombody tell me the pin out for the plug on a syd saloon DPR looking on the plug side led (on rear side) at bottom. Thanks.
PS need it to chip a saloon Slot.it where it is easyer than a saloon chip to mount.
Just look at the wiring of the plug inside the car. Green & yellow are the pickups (inputs); black & red are the motor leads (output). Is this what you need??
Looking at the photo above from Lt to Rt: Green, Red, Yellow, Black
...... what's the grunt of the motor? If the RPM is much above 20k and current draw is about 2A then you could have problems with a Scaley chip.
...... blooming slow forum ..... double post!
You will have to talk amongst yourselves until normal services are resumed
1 - 5 of 5 Posts
