Lol. I actually have a bunch. Took this picture before I added them on. I don’t have enough for all the turns. Starts to add up. I tried some Tyco HO rails. They fit and work, but make it too easy to take turns fast.
Lol. I actually have a bunch. Took this picture before I added them on. I don’t have enough for all the turns. Starts to add up. I tried some Tyco HO rails. They fit and work, but make it too easy to take turns fast.Without shoulders you aren't racing.![]()
I tried to drive once without them and they ended up being parade laps.Lol. I actually have a bunch.
Glad you included the bit about the braids. My car was cutting in and out and finally lost power entirely. I opened it up and sure enough the wire had broken off one of the braids. Mine has the screw in to hold it. The pressure is good enough to hold the wire in? Does anyone solder wire to the braid before inserting it?1) Not so long as the car is behaving itself, especially if the motor already has an EMI filtering board on it, as recent slot.it cars do. But, if the motor is without that PCB, and/or the car behaves erratically, it's best to install the ferrite man, paying close attention to the proper way to install them (as seen on Scalextric cars). There are plenty of cars out there that run fine without them, because they have relatively clean running motors. As long as you remember that a given car does not have it, and are prepared to install it should the car misbehave, you can leave them off. Personally, I install them on any car without the PCB as a matter of course, so I don't have to deal with it later.
2) The plastic bit is part of the clip to help hold the chip in. The hex wrench/key is for adjusting set screws on the car, such as those that hold the wheels and gear on the rear axle, or that set the ride height of the front axle... or in some cases, that hold the braid/wire into the guide.
3. If the guide has set screws in the top of it, just unscrew those. You can then pull the wire out, and pull the worn braid out to replace it. You'll want to pick up a meter of braid. Lean toward thinner/lighter braid if you have a choice. Put the new braid in, put the wire in, and re-install the set screw. Some cars will have an eyelet on the end of the wire that just presses into the top of the guide, and this pressure is what keeps the braid in place. The first few times you do it will be challenging, but you'll get better at it.
As for your final question... read lots of posts.![]()
This is definitely not a plug and play install. You will need to trim the wires, solder the chip in and the use a dremel for removing the tabs the chassis between the front pod posts and trimming down the interior to make the chip fit.Enjoying my first Slot.It and considering another. I'm drawn to the Gulf livery on the "SLOT.IT CA20D FORD GT40 NO. 1" and think it looks slick. I'm a little confused though by the following photo. It looks to have the easy connections for a chip, but doesn't look like there is room for one, nor a hole for the sensor. Is this plug and play like the Porsche above? Does the chip go in the gray motor mount? Looks like there are holes there. Wasn't sure if they were too far behind the guide blade.
Interesting and good to know. It's odd they would make a new car that is difficult to chip despite having the connectors on the motor wires. If the connectors are there, why would the wires need to be shortened and why would there be soldering required?This is definitely not a plug and play install. You will need to trim the wires, solder the chip in and the use a dremel for removing the tabs the chassis between the front pod posts and trimming down the interior to make the chip fit.
I would not recommend this car for someone that is still to new at this game.
Totally makes sense. Thanks. So I need to drill a hole for the sensor on this car, or is it obscured in the photo above by the wires?If you are talking about the slot at the front of the pod with the little tabs at the front and back that is for the key that holds the car to the display case base, it has a T shaped end and just pushes through the slot and is turned 90 degs to hold the car in place.
Both Slot.it and Policar are owned by the same parent company.Another quick question - how are Policar and Slot.it related? Near as I can tell Policar sells tracks and cars, but the two companies are owned by the same parent? I see some Policar cars have the same connectors as slot.it. They use slot.it chips? Are the cars generally computable / comparable in quality?
Somewhat related, is it possible to tell from a Scalextric C# if a car is DPR or not? As in are all cars after a given C# DPR? I can’t tell for example if Scalextric C2642 - Ferrari 330 P4 #24 - '67 Le Mans is DPR or not.
I’m looking to get a Ferrari to go with the Ford above. Haven’t seen a 66 Ferrari out there. Just the 67.
Any idea how hard this is to chip? Probably same challenges as the Ford above? Chassis looks the same.Both Slot.it and Policar are owned by the same parent company.
Policar makes some home-grade cars (like the subaru/toyota) but also some pro-level cars.
Policar is mainly known for their classic F1 cars. These cars are not easy to chip (you can do something with the DPR F1 chip from SCalex if you remove it from its dpr case).
They do also a generic modern F1 car and that is super easy to chip.
I am sure that there is a C# after which they introduced DPR (unless it is from an old mold). I would use the C# and do a google search and see if you can find a pic of your car in a case where it clearly says DPR.
The slot.it chips can be used to digitilise any car once you get rid of the connectors - they are not specific for slot.it and policar.
Most likely it is has a similar level of difficulty.Any idea how hard this is to chip? Probably same challenges as the Ford above? Chassis looks the same.
<b>412P</b> | 24h Le Mans 1967
<br/>412P<br/> #23 R. Attwoode, P. Courage<br/> 24h Le Mans 1967<br/> <b>cod. CAR06c</b><br/>www.policar.it
Thanks. Now I just have to find one. Looked easier to buy at first.Most likely it is has a similar level of difficulty.
