1 - 7 of 7 Posts
Discussion Starter · #2 ·
After a few years of using plastic track we decided to try a extension with mdf. Finally finished the extension after a few hiccups just need to clean up and connect to the plastic section. Now how hard can that be ?
View attachment 304904 View attachment 304905
Wood Road surface Floor Flooring Wood stain
Found out that the coloured slots looked not too bad the paint was far too thick and had to be removed. 馃う
It will be interesting to see how the two surfaces relate for grip. Might make for interesting laps.
However, I agree with Ade.
Yes we thought about that, going to be as you said interesting. Have tested a few cars this morning on the wooden side and it鈥檚 so smooth. Not to sure how long the plastic will stay.
It is pretty typical for the grip on a routed track to improve once it gets enough run time on it -- "rubbered in". Don't be discouraged if your initial grip ain't that great.
Some folks have been known to paint their plastic track. Might be an option if there is a substantial difference in grip between the plastic and the MDF. Painted plastic and painted MDF might be pretty close in grip.
But I agree that you have started down the path to an all-routed track. Once you race on MDF, plastic just won't do it for you anymore. Not only a better running surface, but with routing you open up a wide, wonderful world of custom track design. You can make layouts that are just flat impossible with plastic track. You want a curve with a 48-inch radius? Can do. You want a parabolica curve? No problem. How about a main straight that wanders a little? No biggie! Set your imagination free!
Ed Bianchi
York Pennsylvania USA
1 - 7 of 7 Posts
