1 - 7 of 7 Posts
Lenny Broke
G'Day
I have a couple of fly 917's (K & PA). I find the way the motor pod screws up to the rear body post a bit of pain.
Has anybody glued the motor pod to the chassis pan to make it a one piece unit?
If so was there any plus or negative for doing so.
Cheers, Lenny
Lenny Broke
G'Day Rob
Thanks for the reply
I only use the magnets to hold my club calendar onto the fridge door ,so no worries about that
however I'm not sure what you mean when you say the pod allows the rear of the car to be lowered and lowers the cog.
Cheers Lenny
the rear wheels are on the pod, if you undo the screw, the chassis connected to the body stay as is, gravity pulls it down, loosening the screw then lets the main part of the chassis go lower and the wheels go up into the arches. undo the screw or take it out, put the body on and put it on the track, the rear will now be much much lower
Rob.
I beg to disagree! I have been doing quite well for the last few years with these cars. Having 6 917s and 6 Lola T70s, another dozen or so 908s. In every case, they worked better by agressively gluing down the pod AND the bushings and replacing the sub axles with a solid wire axle.
Prof.Fate
Graham Windle
Is that with or with out magnets Fate,I have always run these tight but with the magnet as close to the rail as I can get,tyres trued ,reduced in diameter.and a solid axle but with the front tyres just clear of the track by a few thou .
Graham
1 - 7 of 7 Posts
